ENERGY AMPLIFICATION
0 Members and 25 Guests are viewing this topic.
Gyula, do you remember :
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=2653497A1&KC=A1&FT=D&ND=3&date=19780601&DB=EPODOC&locale=en_EP
the magnet coil turning process used by the german inventor Wolfgang Klinsing
http://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=2653497A1&KC=A1&FT=D&ND=3&date=19780601&DB=EPODOC&locale=en_EP
and
who gave me the answer to the question about the formula P=....... written in his
description and the answer founded in a russian forum as an old book article about
the Biot-Savart-law :
                            http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=2653497A1&KC=A1&FT=D&ND=3&date=19780601&DB=EPODOC&locale=en_EP
                                                    page 5
                                   IT WAS YOU,thanks a lot !
                  Re:new clean efficient alternative energy source
                                  #22   04.December 2005
                  Klinsing : P=........ ? You,Gyula,answered !
http://www.overunity.com/598/new-clean-efficient-alternative-energy-source/msg3713/#msg3713
      included in the book article a disc ("pancake") magnetic lines modell
      Some errors in Mr. Klinsing calculations had been to be corrected.
But repeating: the search was to construct a powerfull-strong (e-)magnet with
on/off switch process . the  energy source !
Sincerely com todas as minhas  obrigacoes e sem copo de vinho na mao
Oliver Christoph
http://pesn.com/2013/08/03/9602351_TMR-Effect--Tunnel_MagnetoResistance--New_Source_of_Clean_Energy/
stupify12
One primary is composed of Bifilar wound parallel connected in series. Please study and understand the the Tesla Bifilar Pancake. You can create this novel invention even you wound it cylindrical or in toroid.As long as you understand how to create a Capacitor using only Coils.
The main goal is to create Capacitor using Coils. The Copper wire is the metal plates of the Condenser, the Insulator of the wire is the Dielectric of your Capacitor. This is what happens, when we discharge supply Cap to the First Primary(Bifilar) it induced the Second Primary(Bifilar) thus You have now created a (Self Powered LC Tank)Ping pong tech of TWO Primary Inducing each other.
On the Bifilar when we feed with our source the Magnetic Field of Each Coil is opposing resulting to neutralizing effect on the Bifilar which evolve now the Bifilar into a Capacitor.Just practice to make Capacitor using only Copper coil or Wires.
The Two Primaries when both are on its Resonance the energy is being bounce back and forth between both two Primaries.The Bifilar on Resonance is inducing Electric Field and Magnetic Field at the same time  the Energy is being amplified 250,000 times.
Quote from: Magluvin on October 18, 2013, 12:14:33 AM
Thanks Stupify
I had speculated that idea a while back but was not sure, and hadnt gotten to it yet. Was on other projects at the time.
So, does it have to be a 'pancake'? Would seem odd to use cakes in a motor.  ;D
So, when I bifi, used as a primary and in resonance, does not get affected by loading the secondary?
Also, does it have to be a sandwich, 2 primaries and sec in the middle layer, or can it be a single bifi primary and just a single secondary?
Thanks again. ;) ;D
Mags
Magluvin
Quote from: stupify12 on October 18, 2013, 04:40:24 AM
Great stuff. Its all a bit clearer now.  :o ;D I believe I built a coil like this, but I suppose I didnt apply it properly. :-[   Also i like the 15khz to 35khz. Id rather it not be in the radio range or higher.
So where does the secondary come into play? Does it affect the primary function when loaded? Should the sec be between the primaries?
I really appreciate all your help. Tito did tell a lot. But I dont think I got it like this. I guess im not good at riddles. ;D Thanks anyway Teets. ;)
Im going to try some things this weekend. ;D
Mags
Magluvin
1 more question, if you dont mind.  ;D I have many questions. I have only posed a very small percentage.  ;)
Use of bifi in a motor. If we were to replace a normal winding of a motor, would we need to wind 2 separate bifilar windings in place of the single normal coil, or would it be that the the stator is bifilar 'and' the armature is bifilar?  Back then permanent magnets were not used in motors or speakers.  ;)
Sorry for so many questions. This all has made me feel a bit 'upitty' the past couple days. :o ;D :o
Mags
Magluvin
Quote from: weizisky on October 17, 2013, 03:54:30 PM
you push a pendulum for adding some energy to it, When you feel your speed slower than pendulum, release your hand, don't pull it more, as someboy here always say: don't kill the source. only a swich can do that.
weizisky
Hey weizisky
So do we want to push once in a while, or a bit each cycle? A pendulum would simulate an LC, where when the pen is at full swing upward, that would be voltage, stored pressure, and during the fast bottom swing, that would be current flow, then the swing up the other side is the neg voltage build till peak height.
So as to when we should apply the minimum 'push' to keep the pen swinging, is most likely just before or at the natural pen swing height. Left or right top swing height. it would require too much energy to try and add push while in full speed bottom swing. So we want to add push/voltage when the pen reaches or near peak, just enough to take it over the top.
But what has always eluded me is how to take energy from the pen without causing it to drastically slow down, thus needing more push to make up for it. ;D ;D
Mags
