ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
d3x0r
I think the supply voltage for both coils should be a common point and either seperate inductors or the same inductor.   They shouldn't be on a core together...
I've been playing with this oscillator a bit, and added a center-tap transformer backwards; but the simulator doesn't really like that... the coils as done in prior sims are not on a shared core, and coulnd't find if falstad has a way to bind arbitrary inductors...
There is a harmonic between the input inductor and the frequency of the coil; if too big of an inductor is used.
The low ohm pullup resistors need to be high enough that the action from the coils is allowed; otherwise the fets don't go off; and they have to be low enough for an initial trigger to the gates; sort of a voltage divider; but both resistors could be increased after starting....
bleh; without proper inductor interaction hard to say what the real result is... but ya, now I understand where the zero in 'zero swtiching voltage' comes from :)
Dave45
Hey J
Thats a wild coil you designed been watching your vids, what if you wound a primary around the core , Iv designed a couple of coils like yours, torus shaped.
d3x0r
I haven't had much luck with mismatched inductances but yes, a few turn to a lot of turns should also work.  I recently figured out how to properly drive a solenoid coil and be loosely coupled so this will work well for a tesla driver.... putting one of the concentrated focus points at near the end of a solenoid...
now I just need to wire my royer :)  now that I understand how to control its frequency a little
Dave45
bugged up  :)
I used irfp 460
Dave45
I cant let go of the ring magnet setup guess I will have to build it. Just to give an idea
