ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
totoalas
Non disclosure issues and security had been the primary barrier to OU quest.......
If the super rich will only reach out to the so callled OU researchers and their inventions......
think of Mr Dingel     thats a fact of life that were never changed to date so far
totoalas
a.king21
Hmmm.
Well gadgetmall has become a millionaire and they are selling his joule thief open source device big time in the East.
He has also told me things of a confidential nature which will remain confidential.
But then gadgetmall is doing business correctly.
a.king21
This is what a real professor is like:
http://www.youtube.com/watch?v=Jwk_2Zp_P4Q
Tito is not fit to be in the same company.
The real professor shows the Tesla Colorado springs way of energy amplification using a free energy coil.
He also shows the benefit of using thick wire in this coil.
No cryptic comments like Tito.
I suggest you save this lecture. The old scientist is a true hero.
d3x0r
So I've been thinking; as usual.
This new coil generates an apparent 5W from 0.6W....
So, there IS a difference between running current through a 1:100 transformer and getting X/100A and 100X V; and running a current into a resonant tank that is storing a voltage wave 100X of the input voltage.
power in is 100V 0.1A resonance is 10000V and load draws 0.1A
10W input   and effective draw of 1000W  (but can't draw all the input)
power in is 100V 0.1A resonance is 10000V and load draws 0.05A
10W input   and effective draw of 500W (50% of input current; might work)
If you keep the original resonant voltage mostly in the tank, you get to draw most of the 0.1A of input but at 100X the voltage; since it's not really transforming, it's adding.  but have to leave enough to cover... if it's a 80% normal bounce back you need to leave at least 20% input...
Why is back EMF the first thing that happens? I've been backwards using that ...is back EMF on the other side when discussing motors instead of circuits?
Falstad Sim
5.8mw peek in, 2 loads output at 1.79W, power in the tank 22W
so how do I make a capacitive/storage load that resembles a LED? Spark gap?
Unfortunatly; there's not an integral function... the 1.79W is only taken at a low frequency... but I think at a higher frequency than 1/308.... (or even 1/716)
LT Spice fails to generate such positive results.
I think...  the higher the content of the resonant tank, the more the power required to increase it? So really the 100% input is reduced to the 20% effective gain so the power stops growing in the tank, and then taking even 10%... I dunno
It's also a matter of like converting amps to volts... but coverting a long, lower power into a shorter higher power...
Like the old scientist's resonant coil is easily 100X the input... maybe this is the argument to maintain power in = power out...
Otherwise I'd think these fly wheel motor/generator systems would work... storing momentum in the flywheel, so the effective power available is larger than the input; after a time...
forest
No, you must not load the tank circuit....  ;)
