ENERGY AMPLIFICATION
0 Members and 35 Guests are viewing this topic.
totoalas
Just kick the core and it Will  have the same multiplying effect :)
forest
Quote from: totoalas on December 07, 2013, 12:45:20 PM
::) ??? >:( ;D :-*
d3x0r
I recently ran into Vortex water generators; and could use some feedback.
https://www.youtube.com/watch?v=dPIWSVhVHL0
I'll start another thread
1) is the power of a vortex more than the water?  Such that if you have a large water wheel , can it produce 10KW?
http://www.zotloeterer.com/
I went to their site and they have various forms from 0.5Kw to 70Kw... 10Kw is 6M diameter 1.2M drop with a flow rate of 1.2 m^3/sec.
the mass is only 1KW?  In horsepower... foot-pounds of water/min ... think I mentioned that before.
I made some sample vortex generator things uing styrofoam bowls with a (I dunno) 3/8" hole in the bottom....
I used a long plastic bottle with a hole and a tube extended off the bottom, and could get a stronger vortex with more 'pull'(?)
is this a vortex impeller?
Tri-lobe schist (type of rock) bowl; egyptian 1st dynasty
Dave45
Speaking of vortex technology's I dont have access to large amounts of water so Iv been designing a new coil  ;D
I havent hooked it up yet
Tito L. Oracion
Quote from: forest on December 07, 2013, 07:26:17 AM
a tip from Tariel Kapanadze : don't let the impulse die
I think it must work like two-stroke engine
Bingo!!!  ;D
What is the difference if ive'd said it this way: "Don't Let the momentum die" ??? :-\
The important use of the capacitor in our device is to Prolong the Oscillation ok! 8)
Sometimes you are a sharp shooter. That's what i like to you  ;D
@A.king
             I already told that everything is in jumble info but everything is truth. ;)
             I also told how close everyone is.
             No!, i call this rheumatic maglalatik mixing. ;D ;D ;D
             but don't worry i will not close the door. cause the door has a back door of totoalaskador ;D
             shopping shopping muna pag may time. ;D ;D ;D
B.QUEEN ;D
