ENERGY AMPLIFICATION
0 Members and 270 Guests are viewing this topic.
a.king21
Dave45: I understand the Mazilli circuit, but I am unsure about your windings on the flyback. Could you elaborate please.
BTW this ou discovery of yours - has it been recent?
d3x0r
Quote from: Dave45 on January 01, 2014, 12:26:06 PM
Its ironic they say free energy is being suppressed and it is, in the very system used to transport it. Every motor can self run every transformer can self run.
Reactive power is wasted power, give it a path out and put it to work.
The reactive power (bemf) in a standard wound mazilli circuit is dissipated in the capacitor as heat, put it to work.
Overunity is the norm not the exception.
This was an experiment with adding so-called extra-coils as the load of the mazilli...
Extra-coils added to mazilli
I like LEDs as a load for the energy in the tank... can use the high voltage and only a slight current; leaving most of the power in the tank... I ended up using another coil pair inductively coupled with the primary and was able to light an incandescent... so it's not impossible to drive high current, but not directly from the resonant tank... although I guess maybe a tap for the high voltage to a high current transformer might work too...
Lots of ways to use that power; and yes, at that time the available power far exceeds what's available from the source (or used from the source)...
{spoiler; couldn't make the text tranparent... but it's the sum of all inputs... so if it's 100X the power, if you take it all in 1X time, it'll take 100X inputs to get it to (resonant rise) back to that point }
Dave45
Quote from: a.king21 on January 01, 2014, 12:42:56 PM
The bifilar windings on the primary give the bemf a path out, then the bemf is connected to the extra winding on the secondary this is allowing the bemf to do work instead of just dissipating as heat in the capacitor.
In a normal transformer the reactive power is suppressed by the alternating pulse and dissipates as heat in the transformer, bifilar windings provide a path to bring the bemf out then it can be used to do work, add to the transforming action.
Anything that produces reactive power can self run.
Guys Im a little nervous about this, Iv told all I understand do the experiments.
dave
forest
Nice work Dave! I believe voltage is the real energy doing work. It comes from analogy with water where only pressure can do work, and concept that water flow can do work is misleading, flow have pressure and change it into other form of energy !
In water when pressure is changed we know that work was done. In electric circuit due to Ohm law current is unchanged when work is done , while voltage is lowered.
Now reactive power is when we have voltage which has no required amount of current to do work. ;)  So it tries to escape somewhere where it could ...
Grumage
Quote from: Dave45 on January 01, 2014, 02:44:48 PM
dave
Dear Dave45.
I can understand your nervousness you might just have nailed it !!  :)
I hope you don't mind but I have slightly elongated your schematic to clearly show the bifilar. I am right that the Green junction between the primary coils is correct ??
Are you able to give us some extra info as regards number of turns, rotation, gauge and secondary cap value ?? Then a few more of us could help verify your findings.
Cheers Grum.
