ENERGY AMPLIFICATION
0 Members and 608 Guests are viewing this topic.
Dave45
Pulsed dc looks great on paper but will it drive up voltage and amperage or just voltage.
Think alternating current hitting a single coil as in a primary, I think when it hits one side it creates voltage then when it hits the other side it creates amperage if and thats a big if this is true then a pulsed dc coil will only produce either high voltage or high amperage depending on which side the coil is hit.
Extremely high voltage or amperage alone is of no use to us we need both, can both be produced in one system? Not sure.
Dave45
I think this is why Tesla was using capacitive discharge peak to peak. Instead of repetative pulseing one side of a coil he was driving the system using very high pressure in both directions and getting both high voltage and high current.
Grumage
Quote from: forest on January 04, 2014, 04:31:38 AM
simple question : was Tesla igniter patent used in car ? can you trace the actual working circuit from old times ? what was the parameters of components and their arrangement ?
Dear forest.
The simple answer to that question is NO. Tesla's patent date for that device was a couple of years before the first motorcar took to the road !! He is describing a system of HT ignition for the now common, at that time, Gas engines (Gas not Gasoline ) that were for the most part using a method of ignition known as Hot tube !! Ever wondered where the name Chauffer came from ?? A French word meaning  to heat up !!
HT ignition was first tried in the 1860's by Étienne Lenoir but was not very popular because the Spark plug kept breaking down. But by the 1890's they had been perfected to provide a reliable ignition source.
I hope you enjoyed that little trip into the past ? I have been restoring early Gas engines for most of my adult life !!
Cheers Grum.
Dave45
Please bear with me Im just trying to get it straight in my head  ;D
Normally we pulse an alternate pulse into the primary at 180 degrees letting the field collapse and if voltage and amperage move in opposite directions through a circuit this is how it would work.
a.king21
The capacitor discharge is automatic on peak. Every time I pulse 1.2 volts I light a neon.
Tesla is one genius man.
All we have to do is to switch it.
The ozone patent is even  wilder because it mixes the electric motor with the discharge and you get stochastic mixing.
