ENERGY AMPLIFICATION
0 Members and 607 Guests are viewing this topic.
Dave45
Notice he isnt running current from his prime mover through his primary, he's using the cap on both ends. He just using the prime mover to excite the primary.
Dave45
I did the same here and got a voltage increase but not an amperage increase  :-\
But then again the mazilli is a zero switching circuit.
So look at the mazilli what makes it dependant on bemf, the only thing I see in the circuit that would make this bemf dependant would be the diode and its position relative to the coils. The diode has to be the feedback to make the transistors switch.
Dave45
What if the position of the diode were changed from the back of the coils to the front would it then switch at the peak of the wave. Im going to breadboard it this time so I can move things around a bit, maybe Id better order more transistors now  ;D
Reiyuki
Dave45, I don't think a Zero-Cross amplifier is going to get the effect you're looking for.  You need a more disruptive discharge; in the above circuit you are merely pushing the cap back and forth with current.
The best analogy of operation would be a Hydraulic Ram Pump.  http://www.electronicpeasant.com/projects/rampump/pumpdiag.gif
Briefly open a valve allowing a flow of water.  The water gains momentum as it flows.  The valve slams shut and high pressure forces the water to take another path.  In plumbing it is called 'water hammer'.
forest
Seems that motor coils are the only solution  :-\  I tried to make choke from 1:1 transformer in bifilar but current is still too high. I don't like to test Tesla circuit AC version but rather to stick with DC so here is maybe a problem. There is too low chokes for 230VDC
