ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
forest
Not so long ago surfaced a video of 105W self-running device based on concept presented by a.king21. I have a feling it is based on parametric resonance which you can add to the list...
Imho if energy in coil is Li^2/2 and you change L down then I^2 must also change so it rise to fullfil energy conservation law, so if you put that into a step-up DC-DC converter then magically you have rised current, because there is no assumption anywhere that such coil has to be connected to power source, that's the IMPORTANT FACTOR. So as you see if you lower inductance of coil in DC-DC step up converter exactly when coil is disconnected from source current should rise without taking it from source.... theoretically... It's a reverse way of already know and proved concept of changing shape of charged capacitor (capacitance) which rise voltage and power stored inside... (because energy law and charge law have to be fullfiled), because energy is ^2 while power is charge times pressure (voltage). I may be wrong here because it was so badly messed up so it's almost magic mantra that energy and power has to be conserved but it's not truth...
Such setup is simple and straigthforward. Guys, start building now  ;)
DilJalaay
Quote from: Tito L. Oracion on March 31, 2013, 03:51:35 AM
To arrange the electron and make every single electron fall in line from everywhere, then we need to make a continous and actively discharging small energy in the vicinity and fool that arranged large amount of  electron into other door for a very useful and controlled electricity okay?
We don't actually need to produce large amount of input to create large amount of energy but what we need is to control it wisely and effectively through small electronic components.
yin and yang techniques.
The all energy we need is already there, all we need to do is to activate them wisely.  8)
Triode actually is a good controller of large amount of electricity using a very small energy controller. hmmmmm.
Waoo he is talking about Gray tube. hmmm how easy it is.
Its really a buried Treasure.
Thank you sir tito.
GT899
Hi everyone.
I have built 3 pancake bifilar coils so far and a rotary switch. The rotary switch consists of a motor with an upright shaft upon which is fixed a flywheel of 10 cm diameter. I have fixed 2 copper triangle contact plates on opposite sides of the flywheel both soldered to the shaft so they are electrically connected. Touching each plate is a wire so when the flywheel spins it is  half of the time contacting the plates and creating the connection from the capacitor to the pancake coil.
I am not sure what the volt rating of the motor is exactly but it is a toy motor and operates anywhere from 1 to 5 volts and probablly higher. It is a high rpm toy motor.
I gave it a quick try by stacking 3 pancake coils together with the driver coil in the middle and first tried to discharge 12 volts and I got nothing on the other end. I then disconnected and connected it by hand quickly a few times and I got about 0.10 volts at most.
After this I gave it a try with my rotary switch. Once the motor flywheel was spinning quite fast I brought the capacitor positive anode wire and the pancake coil anode wire into contact with the flywheel and a lot of sparks appeared and I instantly got a rating of 2 volts from the 2 collector coils in parallel. So that was rather satisfying.
I used 4 12v 10,000 uf capacitors connected in parallel and being charged by a 12v 5AH PSU
Unfortunately the copper plates got a lot of corrosion and black scratches from the fast make break discharging, even the capacitor wire looked burnt black! Any ideas for a better mechanical switch?
I like the idea of a rotary switch using sparks without any contact brushes but I suppose you then need to use high voltage and I would much prefer to use 12 volts.
I plan to make a total of 9 pancake coils and will give another update soon once there all built.
This is the pancake coil I built with the same diameter and windings: http://jnaudin.free.fr/gegene/gegene02en.htm
Thanks Tito and to everyone for all that you have shared.
Farmhand
Quote from: stupify12 on January 28, 2014, 10:59:13 AM
Okay brother. I will give u my best answer for those question you have posted.
As for Tesla and the guys who actually replicated and understand the SIMPLE principle of this so called Tesla Transformer..I give u my answer Voltage and Magnetism are the same it depends on how u apply and produce that thing.
8)A high current produced a high magnetic field around a wire 8) A high magnetic field around a wire produce a high current-if you understand this simple words you will be amaze. We only need voltage charge in a capacitor=electrostatic container to create A HIGH Magnetic Field- how to do it? Simply successively discharge a capacitor to a wire with  a very low resistance.
How to convert such cold Electricity has already been answered so many times. The so called secret here is the fast successive discharge of capacitor into a transformer. The more coil you induce with that successive discharge the more energy you can recover.The only big problem you guys take for granted is on the RECOVERY/Looping system. All you need is already on your mind/nose, another problem is you guys are like a scientist that Tesla describe on his quote.
Tesla wanted you guys to build and test it for yourself that what he is been telling to us is all TRUE 8)
;D ;D Meow
Tesla this Tesla that, Tesla wanted us to do this and that.
Show me where Tesla claimed free energy anywhere other than directly from the environment ! Hydro, radiant energy receiver ect.
What exactly do you mean by the words you wrote below ? What has he been telling us that is true exactly ?
QuoteTesla wanted you guys to build and test it for yourself that what he is been telling to us is all TRUE 8)
What do you mean exactly Cold electricity ? Where does the energy come from to charge the capacitor ? They do not charge themselves.
Tesla powered his devices with real power. Unless he was collecting energy with a receiver. All normal stuff. No magic performance of things powered by no input power.
QuoteHow to convert such cold Electricity has already been answered so many times. The so called secret here is the fast successive discharge of capacitor into a transformer. The more coil you induce with that successive discharge the more energy you can recover.The only big problem you guys take for granted is on the RECOVERY/Looping system. All you need is already on your mind/nose, another problem is you guys are like a scientist that Tesla describe on his quote.
Please show us some actual demonstrations or show us quotes from Tesla so the misunderstandings can be resolved.
So far I do not detect any party or hoopla and "we found the free energy forever source", so I don't get it, do you have OU or something ?
Cheers
Cadman
@GT899
I am pressed for time, will try to expand on this later, ok?
There are several reasons why you have destructive effects. First of all, read up on RLC circuits. Your driver coil has it's own resonant frequency, to pulse it you need to time the pulse to when the voltage wave in the coil is at or near zero. Also you must do something with the energy from the collapsing field of that coil, do no let it collide with your pulse. Your driver coil is almost certainly a coil with low self inductance and your pulse is too long. Basically you are short circuiting your device and holding the short long enough for destructive effects to manifest.
Timing is critical.
