ENERGY AMPLIFICATION
0 Members and 76 Guests are viewing this topic.
wattsup
Quote from: Magluvin on October 04, 2010, 12:33:55 AM
Hey Watts
I will give it a shot.  Any values on them parts?   Also, it looks to be a switch and a push button to the right of the battery?
Mags
@Magluvin
To the right of the battery is just a master switch. The real magic is happening when that center one turns on and off. The top left coil should have a high inductance. The coil to the right of it is a primary of low inductance feeding the secondary. Both this primary and secondary are considered the "working circuit" part of Tesla's Ozone Patent. The capacitor should be around 47mf.
This simple Tesla circuit employs damped DC pulses and the return to source is incredible. This provides the 2 for 1 bang. This is the only circuit I have tried that has actually given me some serious shocks so if anyone tries it, be careful.
When you do your simulation like this, is there a way that you can save it and export it as an animated gif so you can put it on this thread while still having the animation working.
Magluvin
Sometimes I see a circuit that is just oriented differently, and it takes me some time to say hey, thats the same circuit.   Your right Forest, the igniter and ozone are very similar. There is that difference that I described just a bit ago.
Actually I did not see Watts circuit as the same at all till now.  I assumed that the 2 coils inline as the primary, well I thought it was all primary from left to right with a center tap.  lol   I would not have assumed that the coil on the left was a large inductance compared to the right.
Either way, Forests circuit is what you are looking for. As to whether the Igniter will produce the same exact result is yet to be seen, but they have all the same ingredients and functions, all with the exception of the position of the cap and switch. If the switch is across the large inductor/source directly, it is Ozone. Now change positions in the circuit, the cap and switch, to where you have the cap across the large inductor/source, and you have the Igniter circuit.   Hmmm   when ever I looked at the ozone pat, I couldnt get a grip on it. But if this is it, they are very close to being the same.  The igniter was simpler to recognize the functions within the circuit.
I have a screen capture prog that i can try to make a lil vid, and if it is small enough, Ill post it. 300kb, aint much.
If I squeeze the components and move it close to a stacked scope shot, Ill try to fit it if all works well.
I will try to do a circuit with your 47mf (is that micro farad, or milli farad?) and see what can be had.
Mags
Magluvin
Ok   made a small vid,  It is very short to qualify for upload. Hopefully it replays faster on post than in jet audio
Lets see
Mags
Magluvin
Hmm   not the way I planned it.
Mags
