ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
a.king21
2 x 50 mf capacitors in parallel =  100 mf
2  x 50 mf capacitors in series =     25 mf
Dave45
QuoteOne more thing, about Tesla's bifilar coil. I made an interesting setup once, basically a solid state Bedini type oscillator, but instead of having a cap receiving the coil collapse I connected a bifilar coil. Meaning the output of the power coil was connected to a bifilar coil with a diode (like in normal Bedini setup). The wires on the other side of the bifilar were left open. Running the circuit for even just a fraction of time would charge the bifilar coil like a cap, and the neat thing was that it could sit there for hours after the circuit had been shut off, when I would short its open wires it would discharge with a bang just like a cap, well, because it is
Following that train of thought we can wind a capacitor directly on a core and create a high electrostatic potential on the coil, what happens if it is discharged back into another winding on the same core.
Will we get an electrostatic collapse like a magnetic collapse, very very interesting.
The bifilar wound cap coil would charge itself, not need to charge it just a discharge path........ right?
a.king21
DJ, A friend of mine tried your 3 cap circuit on a relay.
There was no energy gain, but there was a constant voltage.
So, listening to Tito and applying the Tesla method we could try this next.
Insert a 2 turn Tesla primary into the circuit.
Better if the secondary is bifilar?
crazycut06
Quote from: stupify12 on February 02, 2014, 09:13:10 PM
Hello everyone.
8) what you have is the proof of the what actually the true nature of capacitor and a cap discharge. Okay i give you this hint. All the necessary parts and set up to have free energy has already been posted here and well understood by our friend a.king21.
I will explain it in words. We need a pre charge capacitor lets say 1.5v in a 1uf to 10uf 250v to 400v cap ( the purpose of smaller capacity is to fill it with charge faster) , then we discharge this cap to a coil which has very low resistance-we also have a many turns of secondary coil which is induced by the capacitor 400v discharge which make will result into multiplication of electrostatic energy. The output of the secondary is to charge a HV cap lets say .50uf 2000v to 4000v, this 4000v energy is to create a HF transformer( this is the part which create the extra energy=frequency)- the primary is also a very low resistance which also has a Secondary- capture only the charge which is more POSITIVE=Spike/Surge of CEMF/BEMF to charge another BANK of capacitor it depends how many capacity you need- it is still be charged faster because you have here a HF charger.Again capture only the POSITIVE and connect it  on the POsitive of the BANK, and for the negative- I already give you all the hint of it to where you will get it. We call it charge funnel of energy from the environment.
The capacitor Bank should be timely discharge back to the first capacitor when your switch of the cap 400v is OPEN Circuit. So you can charge it fully. At the same time the path of your discharge is true a transformer, so clock your discharge with 50/60hz.
P.S. with capacitor discharge you can also fast charge a battery it depends upon your frequency of choice. The pre charge could be from 9volt battery, electrostatic machine, Aerial capacity.
Wow thanks! it seems that you have already done this part, any pics or videos that you can share?
wings
Quote from: a.king21 on February 03, 2014, 06:36:45 AM
I am in trouble it is not an equivalent capacitor because we are looking at the charge accumulated when in parallel see this video :
http://www.youtube.com/watch?feature=player_detailpage&v=xgQt8dRhDnE#t=337
I am correct?
