ENERGY AMPLIFICATION
0 Members and 165 Guests are viewing this topic.
Tito L. Oracion
Quote from: Magluvin on February 04, 2014, 10:23:31 PM
Im not sure any of that helps. ??? But maybe this does. ;)
If what Dyson is saying in this vid is true about multiplying the air out compared to the air in, how can we apply this to electronics?
http://www.youtube.com/watch?v=8he8afjQyd8
Mags
Well, buddy for me if i'll consider the middle space as the core of a transformer it would be better if we make the coil in bifilar, and the concentration of effect is in that part of space.
still just a bifilar coiling of tesla  ;D
in short nothing is new sorry. ;D
Well, we can change the core into coils like what we do in toroid 'Xformer. :-\
in my other point of view, it is acting as an accelerator of some thing that is not holding physically but by mutual in other form. 8)
Magluvin
Hey Bud. Well, I guess Ive done it wrong many ways. ::) ;D
When we are talking about bifilar, are we looking at just a few turns, or many? If few, then not much more capacitance than a normal coil If many. If many, should we worry about too much resistance of the bifi winding?
I have more questions, but these are important first.  Like we look at a typical Tesla coil for example, and the primary is generally low turns. And all the writings of cap discharge into stout  primary, is that old news and replacing with a high turn bifi is better?
Thanks Teets.    :-* ;D
Mags
Magluvin
Quote from: Tito L. Oracion on February 04, 2014, 10:48:47 PM
Mutual by another form? Electrical field?
Coincidentally, fiddling with my Lasersaber motor over the weekend, I think I got a taste of what the electrical field is all about. Just a taste, I think. It is something I may have never seen if it were not for this motor.
The motor has 24 coils in series. Each coil, 3200 turns, No. 42 awg wire, is about 650ohm and in series 15.6kohm.
While fiddling, I was running the motor off of just 3 of the coils in series, and the other 21 in series to see what the output would be from them. With the 3 coils in series, 30v in(reed switching) I get near 2000 rpm and the 21 coils in series put out over 500v. Now out of 13.6kohm(21 coils) there isnt much current. ::)
Now to the finding.  I have an old wire tracer used in telephone service. The part Im using is the receiver, which picks up all the noises of the reed switching, etc. anything that makes an electrical noise that is audible, this thing picks it up, louder with closer proximity.
While listening in with the noise probe, when the speed and voltages get up to what I stated, sniffing around the 21 coils in series, with open ends, there is this tone coming from the coils. But, the tone is loudest towards the first and last coil, and relatively quiet in the middle coils of the series of 21. Its not from the 3 driver coils or reed, as the tone effect is still there when input is taken away from the driver and the rotor is winding down.
So all that wire, almost 2 miles, there is charge being pumped back and forth in the coils(open ended, no load, and it is creating an electrical field at each end of the series chain.
I plan on doing a vid on it. Its not something you can see with a single open winding on a transformer, where you can see not much field change in the middle as I can see with all the coils in series.
Anyway, Just trying to make a connection. ;)
Mags
Tito L. Oracion
Quote from: Magluvin on February 04, 2014, 11:20:14 PM
mags : Hey Bud. Well, I guess Ive done it wrong many ways. ::) ;D
otits: No buddy, you're just kidding me. :D
mags: When we are talking about bifilar, are we looking at just a few turns, or many? If few, then
           not much more capacitance than a normal coil If many. if many, should we worry about too
otits: This is actually depends on what you are doing and for durability,
          lets say for primary as the driving coil, it is safe if 36 turns times 2 AWG14 cause we don't
          need much capacitance in the driving coil as long as there is a back supporting coil other than
          the source. as much as possible there should be no resistance in the driving coil that is if
          possible. To achieve the maximum effect of the core.
mags :I have more questions, but these are important first.  Like we look at a typical Tesla coil for
otits: for me it still depends on the source if we use high turn bifi in primary then resistance is
         bigger if we only use 12v  ;D [size=78%] [/size]
mags: Thanks Teets.    :-* ;D
otits : thanks too next time buddy bye. ;) [size=78%] [/size]
Mags
that_prophet
You use pulleys to multiply your rotations
And with electricity, more rotations is equal to more AC electricity
The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are multiplying the power.
We don't need the air polluting effects of the combustion engine any more
We have self-generating electricity generators
That can be made to practically any size or voltage
So that we have the choice to have almost everything self powered
I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.
I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
I figure that if you keep adding output generators to the belt
then you would eventually generate enough power
to make up for the power that you are putting into the drive motor
as well as any losses due to friction
until you add enough output generators
to have not only have a self powered machine
but you can get an excess of power as an output
= free energy output generator
Here are a few of the reasons for this system to work miracles
- The massive circumferential differences between a large drive rotor
o You put power into turning a motor only once-(lg)
§ When the power out generator(s) spin hundreds of times faster
· Each rotation gives you power to put back into the system
- Then you could add tens of these output generators
o All of these would be turning the many hundreds of times faster
- Them you could enlarge the drive motor pulley to the max
o As well as shrinking the size of the pulleys on the output generators
§ to make the multiplication factor even more
- So lets see, you are putting energy into the high torque motor with a large pulley
o And then through extreme size differences in pulleys
§ As well as the simple addition on 10`s if not 100`s of generators
· You get your many generators to spin many rotations
o That you are getting power out of
§ While your input motor only turns the once
· You have to make power
You need one DC motor as an input motor
Then you need at least one AC motor as a generator
This is one of the easiest way to multiply your input power
By adding additional output generators
on the same belt as your input DC motor with the one large pulley
Or, you could change size of the pulleys is another way to effect your multiplication
by shrinking diameter of output generator(s) pulley
or increasing diameter of DC input motor pulley
are other ways of increasing you multiplication
the drive motor and all of the generators could be any voltage
as long as they are of the same voltage
you might need to use voltage regulators
to keep this contraption running smoothly
Maybe this mechanism should be called an electricity multiplier
As you always need the initial amount of electrical power
To be multiplied into your gaining of free energy
Which can be initialized by giving the large pulley a turn by hand
this is a Miracle from God
yes, it does indeed work
using size change in diameters of pulleys
to multiply the rotations of your input motor
by the large change in circumferences of the pulleys
as in, the multiplication factor is due to
the tens if not hundreds of times the circumference changes
I just don't like the idea of somebody blowing up a battery
And maybe even catching fire
Now, most likely you will not be interested in this Spiritual part
But I discovered this by praying and asking the God of the Holy Bible
for a way to help us earthlings, the Tribulation Saints mostly
Especially during the 3.5 years of the Great Tribulation
Where they will need a way to survive our cold Canadian winters off the electricity grid
Don't believe in Satan or evil forces
Please explain why this simple idea
Of using change in size of pulleys to multiply electrical power
Has not been discovered all ready
to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters
WARNING = the pre-Trib started on March 14th, 2012
http://lie .yolasite.com/
joe lynch
one_christian_warrior@yahoo.ca
http://beliefstoliveby.yolasite.com/
( ok, I know that most will fall for satan's LIE, the religious belief of EVilsOLUTION )
