ENERGY AMPLIFICATION
0 Members and 44 Guests are viewing this topic.
totoalas
Quote from: gyulasun on February 08, 2014, 09:24:34 AM
Hi Totoalas,
It is very kind of you to mention that "my circuit" gives 40 watts out at zero watts in (if I understand it correctly)  but it is not "my circuit",  I simply drew a schematic as per Tito's description, you surely recall this:
http://www.overunity.com/6763/energy-amplification/msg352107/#msg352107
You also drew a setup later on with an E ferrite core included in the circuit, http://www.overunity.com/6763/energy-amplification/msg352229/#msg352229   and if you could comment the exact circuit from which you receive the 40W output, that would be useful for everybody here.
Thanks, Gyula
Thanks Gyula for your humility
Without you we cannot decipher Tito's circuit
The only difference and there are lots of ways as Tito said  switching method
I started with ssg pulse /pwm ignition coil to charged the caps
when the pwm failed due to HV from the ignition coil
I put it directly in to the relays
Dc input from the Analog meter showed zero when I switched off the wall power supply but the lights are still on ( 8 pieces 5 w led bulbs)   the water tap is connected to the e core
Everybody can check my previous post
From there I need to simplify everything  :)
Dave45
totoalas
Tests result   post 2851  by romerouk
gyulasun
Quote from: totoalas on February 08, 2014, 05:22:11 PM
Hi Totoalas,
Thanks and you wrote earlier that when you removed the wall adapter from the mains plug, the LED lights went off while when you switched only off the wall adapter but did not unplug it from the wall then you had lights?
( http://www.overunity.com/4728/is-lindsays-sm-a-fraud/msg128233/#msg128233 )
So how things have been going since then, you managed to improve upon that circuit to get the 40 W?  Can you give details.
Greetings,  Gyula
