ENERGY AMPLIFICATION
0 Members and 53 Guests are viewing this topic.
Dave45
Do the wire leads act as antenna's?
forest
No Dave45. You got it right previously. Again back to Tom Bearden moving picture  ;)  Save it and analyze frames. That is the essence when simple Farmhand "activity" converts into magic Tesla ACTIVITY.
Cadman
I suspect this post will be largely ignored but here it is anyway.
May I suggest that you first build the circuit "as is" without trying to reproduce one with modern electronics? Use 60 VDC, that was a DC mains current available in those days. After you see what it is actually capable of, and understand it, then modernize it if you wish.
Studying the patent, ask yourself "why are there two controller disks insulated from each other?" In the circuit as drawn there is no practical reason for that. The patent is clear that there may be more than one condenser and the condenser may be small and inexpensive. If it may be small, why mention there may be more than one? Perhaps for the same reason there are more than one controller disks insulated from each other?
The purpose of the large self inductance choke coils is obvious, as in the electrical igniter for gas engines. Low input, high output to charge the condenser with one pulse.
When the condenser is shorted and the transformer primary is hit with the pile driver current from the condenser, the secondary is going to oscillate like crazy and will in turn induce oscillations in the primary tank circuit(s). Perhaps that will be enough to charge a cap or two?
And who says the transformer can only have one heavy primary winding? -|-------|-, -----||-----. The patent drawing clearly shows two K.
Also, from the patent, "..utilizing the intermittent or oscillating discharge of the accumulated electrical energy of a condenser or a circuit possessing capacity.."
" or a circuit possessing capacity", heavy TBC primaries anyone? Maybe, maybe not.
And I haven't even mentioned the secondary coil AC output.
Bruce_TPU
Quote from: a.king21 on February 09, 2014, 11:19:24 PM
TITO::
HOW CLOSE ARE WE NOW???
https://www.youtube.com/watch?v=BK3OiVfwmoQ
I hope FAR FAR away.  That video, no offense to someone at least experimenting....is useless.
P = V x I  No I measured across the input, no I measured across the output.  Sorry to bust any bubbles.  A few more volts on the output is USELESS.
Cheers,
Bruce
Grumage
Quote from: Bruce_TPU on February 10, 2014, 04:15:10 PM
Cheers,
Bruce
Dear Bruce.
Non taken !!  :)
What I did not understand was the fact that a 1:1 ratio transformer created a non 1:1 ratio output. With a load attached as well !! Could you explain the reason for me please ??
Cheers Grum.
