ENERGY AMPLIFICATION
0 Members and 127 Guests are viewing this topic.
Magluvin
Here is another Moco circuit with 1.2v source and tuned a bit more to just over 10 times out than in
Mags
Magluvin
So this is what "kickin" is Teets?   just kickin the inductor along to keep the flow going? FEMF
Hmm  Thats what we have been talking about boys, the inductor flywheel, with a lil bit of jiggle in the load section. That I have also brought up earlier, if we have a resonant circuit, if it is damped by the load, it may only get a few cycles, but if one of those cycles is as big or bigger than the input pulse, the the rest of the waves are free, the few we have left before the next input pulse. This is good.  Its seemingly a lot clearer.
It seems as though we could get these functions to work mechanically.  Really, Im not seeing energy from the vacuum, Im seeing energy of the function.
I like this Moco setup.  I have some Tesla circuits of different sorts from Colorado Springs Notes that I need to gander at.
Well, its just a resistive(light bulb) load here, but it should prove valuable if it works. Gotta get some sleep, tomorrow is a new day. ;]
Mags
forest
forest
Mags
You are  ;D ;D  ;) just imagine a Tesla doing  discharge from capacitor
Why the hell he used so many ways to make it DISRUPTED ? Magnetic quenching, hot air,rotary controllers,multigap spark gaps etc
I think it was not clearly described in any thread . May I be right sir wattsup ?
http://www.youtube.com/watch?v=b20z95XcaX8
http://www.youtube.com/watch?v=VdUzpCgAhmA&p=BB4978E4DAE172CC&playnext=1&index=31
wattsup
@forest
In many cases Tesla did not have the high voltage available to then discharge it directly into his coils. He had to first produce the high voltage from the voltage that was available to him either through a stand alone generator, a battery bank or directly off the mains, store it, then discharge it into his coils. The Tesla Ozone Patent is one means of economically generating high voltage. But like @erfinder once said, "who said you have to then just produce ozone". lol
The idea behind producing output is easy. The idea is to get the energy that is produced completely out of the production side and safely banked on the output side. The sooner the energy is removed from one side, then this energy can no longer work against the production side. The production side sees the output bank is empty so it can now recharge it fully from 0 to full again making each cycle as productive as possible. If the load side is consuming 80% of the production, then there is 20% that is always stagnant the production side now has to start at 21% to increase the bank again. But the production always starts at 0 so it has to reach 21% to now add 1 more to the output side. The idea is to keep the load away from the production so the production always sees a return resistance of 0.
I think @Tito is referring to the zener diode to accomplish such a separation but only once the production side has reached a minimal level. This then discharges into a separate holding system possibly through another voltage increasing method so the next cap tank can then hold higher voltage. But it is always left to some level of guess work.
One example of this uses simple switching to keep the input side far away from the load side. So let's say I will give you 1 volt forever. You can take that 1 volt in one second, or you can take 1 volts 10 times a second, or 1000 times a second. You will always have a 1 volt available for as fast as you want to catch it. But it is only 1 volt. So what do you do? I have made an animation some time ago to show such a switching scheme to catch that 1 volt, accumulate it, and pass it on to a next stage that is totally separate from the feed side. It all has to do with switching capacitors. This is a very tedious method but is shows the step by step of what is involved.
You can see it here;
http://purco.qc.ca/ftp/Wattsups%27%20stuff/voltage-grabber-circuit-VGC/
Just click on the gif file.
But here is the clincher. I could be totally off the track as far as @Titos device is concerned and this is the danger of discussing stuff on a Forum. Sometimes, someone opens his mouth and guys can then swing their attention to other avenues that just lead to dead ends. So please do not take what I am saying here too seriously. In a way, my stomach is full already with all the guesswork we went through with SM devices, and so many other mystery devices, and @Tito is just another source or reason for more guesswork. It's always the same thing. No one has the faith. Everyone only thinks of himself. Wow, I wonder where we would be if every man on Earth past and present lived that way. We'd be up Shits Creek without a paddle, actually without a boat.
