ENERGY AMPLIFICATION
0 Members and 209 Guests are viewing this topic.
forest
sir wattsup
Sorry if I misunderstood but I think you see only one side of the coin  ;D
Something I already knew long time ago , and this is what Tesla described a magic in capacitor - that you can discharge it very fast thus managing any rate of energy flow....The second side of coin is not described except in Tito tips ;)
Magluvin
Yes Forest,   ;D ;D
Im happy about this.  I have been thinking all day.
Im running some test runs on my 2mh coils as a pulse motor, like a bedini, but with extra coil, like Moco.
In the past on some of my YT vids, when I thought I was catching bemf, I was really catching femf.  I have to go through them to see which ones.  I remember the diodes being backwards but working, and I just assumed that it was bemf, and didnt know femf even existed at the time. Not that they went in depth one the subject back then. .  Lol  like when I said  Left Hand Rule.  Its right hand. lol
Feel like a fool at times.
The tings we remember and the tings we forget, or get twisted.  =]
Mags
forest
Quote from: wattsup on October 12, 2010, 09:19:36 AM
@forest
In many cases Tesla did not have the high voltage available to then discharge it directly into his coils. He had to first produce the high voltage from the voltage that was available to him either through a stand alone generator, a battery bank or directly off the mains, store it, then discharge it into his coils. The Tesla Ozone Patent is one means of economically generating high voltage. But like @erfinder once said, "who said you have to then just produce ozone". lol
The idea behind producing output is easy. The idea is to get the energy that is produced completely out of the production side and safely banked on the output side. The sooner the energy is removed from one side, then this energy can no longer work against the production side. The production side sees the output bank is empty so it can now recharge it fully from 0 to full again making each cycle as productive as possible. If the load side is consuming 80% of the production, then there is 20% that is always stagnant the production side now has to start at 21% to increase the bank again. But the production always starts at 0 so it has to reach 21% to now add 1 more to the output side. The idea is to keep the load away from the production so the production always sees a return resistance of 0.
I think @Tito is referring to the zener diode to accomplish such a separation but only once the production side has reached a minimal level. This then discharges into a separate holding system possibly through another voltage increasing method so the next cap tank can then hold higher voltage. But it is always left to some level of guess work.
One example of this uses simple switching to keep the input side far away from the load side. So let's say I will give you 1 volt forever. You can take that 1 volt in one second, or you can take 1 volts 10 times a second, or 1000 times a second. You will always have a 1 volt available for as fast as you want to catch it. But it is only 1 volt. So what do you do? I have made an animation some time ago to show such a switching scheme to catch that 1 volt, accumulate it, and pass it on to a next stage that is totally separate from the feed side. It all has to do with switching capacitors. This is a very tedious method but is shows the step by step of what is involved.
You can see it here;
http://purco.qc.ca/ftp/Wattsups%27%20stuff/voltage-grabber-circuit-VGC/
Just click on the gif file.
But here is the clincher. I could be totally off the track as far as @Titos device is concerned and this is the danger of discussing stuff on a Forum. Sometimes, someone opens his mouth and guys can then swing their attention to other avenues that just lead to dead ends. So please do not take what I am saying here too seriously. In a way, my stomach is full already with all the guesswork we went through with SM devices, and so many other mystery devices, and @Tito is just another source or reason for more guesswork. It's always the same thing. No one has the faith. Everyone only thinks of himself. Wow, I wonder where we would be if every man on Earth past and present lived that way. We'd be up Shits Creek without a paddle, actually without a boat.
wattsup,
assume you have a big heavy obelisks in domino fashion  :D you need a big buum to move one but then you need nothing more
and yes,rate of change means more then power
actually yours words are not bad at all  :D   just place a little twist here and there  ;D
quench store shake some LEFT   ::)
because you can have 1 volts forever   ;D after
http://www.youtube.com/watch?v=t3McwWIqzTM&p=64A847BB73E93C6E&playnext=1&index=43
actually I checked and it does not depend on capacitor, big, small high low behave the same way as in video but for igniter patent it has a meaning
8)
