ENERGY AMPLIFICATION
0 Members and 65 Guests are viewing this topic.
Google
Quote from: totoalas on March 01, 2014, 03:27:23 AM
If parts are available in generic or other equivalent  then we can start easily
Hope we knew of forest build results
Xname 41 has modified but without video
There are t least 4 modifications   so which one   works best
Stevpue can verify this circuit but i wonder he's quiet till now
So now just  it'swaiting game
8)
Kapanazde tech has been around since 2005, 9 long years. But no one knows the secret yet. Others who claim to have replicated it, do not share their exact circuits and parts.
I was just wondering, why show on youtube, when you dont want to share the tech. Kapanazdes invention has not made him rich. Steve Marks invention has not made him rich.
No one can make money on free energy circuits. It is proven by the above two examples.
FREE ENERGY = FREE INFORMATION.
Or else take your secret to your grave like Hendershot, Moray, Paul Baumann and others like them.
If you share the secret, you will be a hero. You will be protected and welcomed in all homes across the world.
So think guys.
Best,
Google
I had written to a renowned physicist about Eric's "Flux capacitor". I had sought his opinion about the "energy synthesis" process by which Eric is able to charge his batteries without external power input. Here is his reply :
" I don't see any circuit diagram in the video other than the burnt up vibrational switch. Obviously the capacitor was discharged through this vibrational switch and generated a lot of heat. It is still a spark gap style device. Even after all the heat generated, it seems like the discharge current could charge up the other battery. I think it is interesting but the mechanical switch like this is not reliable in the long run. It just proves that the capacitor does have a lot more energy than what the conventional theory says."
I am seeking his expertise in Physics and Electronics to guide me in making something worthwhile which exploits this phenomenon displayed by the capacitors.
If something good comes up I will immediately share it.
Best,
totoalas
Quote from: Google on March 01, 2014, 10:15:53 PM
Best,
thanks for sharing that info
mechanical oscillation for 20 years is not bad  for that type of vibrator
my solution to that is use a hv  on the relay where there is arc even without the relay moving
battery   no      cap with hv   common    battery 24 v   nc
ive tried that in my Infinitum lighting @ 40 watts   but by using a regular 12 v wall adaptor   and water tap
the flyback can be run by a 1.5 v AA battery and min 5 mA   up to 85 ma
that can replace my ignition coil to charge the caps
an improvement in Gyulas circuit is another feedback coil wrapped in the bifi primary in series with the secondary ( discussed here in another thread)    a gap in my e core increased the ac v from 110 to 347 v ac open circuit
totoalas
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg390329/#msg390329
Element 6 has mentioned a guy with his efficient UDT
reading thry this has some similarities with Gyulas circuit of Tito
His using AC  while in Gyula  is DC
A combination / coil turn calculations will produce better results
Maybe Gyula can take a look at this info
and I can revive my tests again  8)
DilJalaay
Hello all,
I suggest make the PWM seperate circuit while replicating Akula 30w.
Here is my penny to you..
Just make a few print to shrink and fit to the components. i hope with two or three try it will fit to components and save the time.
Best of luck for every one. Remember please share your results.
Regards,
D.J
P.S: Remember you can get TL494 from any old or burnt computer ATX power supply.
