ENERGY AMPLIFICATION
IWD
If next thing to mix to this mumraj is avramenko.
$ 1 5.0E-6 10.391409633455755 50 5.0 50
d 224 80 448 80 0
d 672 80 448 80 0
w 224 80 224 368 0
w 672 80 672 368 0
c 224 368 448 368 0 1.0E-7 -9780.42923460616
c 448 368 672 368 0 1.0E-7 9780.429234618226
w 448 80 448 112 0
R 448 112 448 128 0 2 40.0 5000.0 0.0
r 448 368 672 224 0 1000000.0
r 448 368 224 224 0 1000000.0
r 448 448 672 448 0 100.0
A 448 272 448 176 0
g 672 448 672 544 0
c 448 448 448 512 0 1.0E-5 4.4783854611084335
g 448 512 448 544 0
d 448 368 448 448 0
d 448 272 448 368 0
o 10 64 0 3 40.0 0.4 0
When square wave is HV coil, ground is clasical earth and antena can be just wire. then the 100 ohm resistor is the load. Of course this simulation is not exact. Because planet earth is hard to simulate.
nievesoliveras
Is it this what we are looking for?
I mean Magnification or amplification?
Jesus
Tito L. Oracion
The process of the amplifier referred by tesla is explode then stop and listen then explode again then harvest the wires.
The other brilliant one is explode then a wave of explosion will next to it without a connection from the first explosion then harvest the multiple gain made by the first small explosion.
ooops don't forget the recursion and cron to make a perfect timing in loop.
NOTE: This technique can lead into a masssssss destruction so be careful. a loop should be in control or else LIGHTNING WILL APPEAR INSTANTLY! AND MAKES YOU CRISPY AND DELICIOUS!!!
;D
Tito L. Oracion
Another Example:
Let say for example everyone is holding a candle, starting from me, i will lighten the two and the two will lighten the four and so forth lighting everyone by everyone.
This technique is the rolling ice stone or falling domino and this is the ultimate amplifier of tesla that was not directly recorded but we can see the first steps in many of his patents.
All we need to do is RE.
That's it, i have given you the closest tip i could give, i hope you can do it
Good luck once again, be careful and bye.  ;)
Otits L. Noicaro ;D
Magluvin
Thanks Teets.  Its hard to imagine the dominoes, as after the have all tipped over, we have to reset them all again.
But im sure your tips will get us there as we go along.
I also believe you about the lightning. I have not done it yet, but I can see that the voltages can get way up there with the right ingredients.
I like the 2 diodes on the end of the secondary with the load.  I read that article many times. I am going to try that at some low voltages, as the article says it can be done.  I am thinking that possibly this  can be done with many coils and outputs, without affecting the source. I think, from what I gather from the article.
My projects of late have been dull.   I get full of excitement then depressed a bit. But I have been there many times and it is becoming easier to deal with.
Im in a process of moving again.  But, I didnt really unpack most of it while I was here. So it will go smoothly.
Some moving this weekend and next. So I still have time to party with the coils and caps during the week.  =]
Thanks all, you all bring a lot to the table and it helps my enthusiasm.
At lunch   bbl
Mags
