ENERGY AMPLIFICATION
0 Members and 58 Guests are viewing this topic.
Mr. Teslonian
Friends,
Please have alook at my posts #s 560, 561 and 562 on the following thread. Very impotant hints by mr. Tito. We need to decode them.
He suggests the following :
Antenna ----> Many ordinary transformers -----> Inverter (1000 watts)
http://www.overunity.com/5772/teslas-magnifying-transmitter-amplify-electricity/new/#new
  ---- Mr. Teslonian
Mr. Teslonian
Mr Forest, I am quoting below from you and mr tito. Shall be grateful if you can in simple words explain why there are huge current spikes with the extra coil ??
I believe if extra coil is used in a reciever, it will still give the same current spike based on displacement current you explained.
Can you imagine and post a simple schematic to help us proceed further ?
solid state devices / Re: Tesla's Magnifying Transmitter (amplify electricity)
« on: February 20, 2010, 12:40:41 AM »Quote from: forest on February 19, 2010, 08:19:47 AM
MR FOREST :
Excess coil or extra coil in Tesla magnifying transmitter produced extremely huge voltage when oscillating freely. It is the analogous of whip  or swing. Now we call it antenna.The solution is clear ! however essential part is missing.Tito is using extra coil to generate extreme voltage from small power source, but he found a way to use it as a pump - sucking displacement current from ground or air and generating current spikes. Apparently it is not easy because we are misled by current knowledge about power in antenna being not real.Correct - it is reactive most of the time, but I'm sure there are ways to make it dissipate power into envinronment.Read Colorado Notes - Tesla suddenly found that sparks from elevated capacitance of his magnifying transmitter can reach thousands of amperes.That was  surprise.
MR TITO REPLIES :
@forestYES! bingo you are absolutely correct with this quote!@barof course the many the extra the many the gain but be very careful if you are using thick wires with caps cause it will make you fried and crunchy  and sometimes, a sudden and unexpected lightning is produced in the near of you so be very careful sir!  better wear many aluminum with magnets insulated to you to save you from this funny but dangerous experiment  Bye friends AND God bless and BE VERY CAREFUL CAUSE YOU WILL NOW PLAYING WITH LIGHTNING OK
Mr. Teslonian
Friends,  in the following quote from mr tito everything is clearmand simple : This is the first method he used for excess energy. Second methos is Antenna method and is more complex one. I propose focussing on this one only initially.
MR TITO :
@all as what i have told you before there are two method.   i have given you the main ingredient of the first method of my discovery and that is the bigger version, now the smaller version used by SM, hubbard, moray, smith, hendershot, and tesla etc. is mine Ha!ha!ha!ha!ha!
now again start become mad at me again   sorrynow catch if you can catch
  make a deep research and experiment on these:
a) zener  - to regulate battery loopback charging voltage ?
b) resistor - to minimise usage of current from source battery ?
c) carbon - for contact points ?
d) computer fan motor - for make and break ?
e) battery - source
f) coil - high induction coil and pickup coils ?
g) caps not a big deal ok
h) vibration and sounds plus the speed of light - very high speed make break / cap shorting in bifi coil to create hude momentary magnetic flux, which are picked by secondary as high current ?
This method uses battery as source and doesnt use Antenna and Earthing. This keeps the battary charged and gives input for inverter also with sufficient current to get 1kw of power from inverter.
The other method involves use of three different frequencies via antenna(s) which are fed to the TPU and drives the TPU in the Overunity mode.
At least thats how I see it happening.
We may ignore the TPU Antenna thing for now and focus on the first method.
  ----Mr. Teslonian
Bob Smith
Great stuff Mr. T
Just another tidbit to add -- Perhaps a year ago, Tito advised putting a simple parallel wound bifilar coil perpendicularly across and around another coil to stimulate the ringing effect. I think Magluvin and I tried this, and in my case, by pulsing the bifi coil, I was able to get a ringing down effect in the larger coil, but that was about it. Looking back, I realize that wasn't the whole picture. I needed a better coil config in the secondary. However, the perpendicular coil principle might be worth filing away for down the road.
The way I have seen this apparatus for some time is in terms of the following principles:
Antenna - Caps - Diodes - Possible Joule Thief (kicks) - Series Wound Bifilar Coils arranged in series, discharging into one another to amplify voltage.  The question at this point is how to take power from this setup without damping the oscillations or killing the dipole. I think the TMT points us in the right direction, and perhaps Forest's remarks are good food for thought on this. :)
Here's a hint that may help us with the caps and diodes arrangement: look at what Synchro1 has done with his quadfilar setup. I think it gives us some indications on how to arrange caps and diodes. He also goes by Allen Burgess over on EF and another name on Youtube (linked in his posts).
Off to work...
Good day everyone!
Bob
totoalas
as erfinder said in energy science f
RECOVER THE RECOVERED ENERGY BACK TO THE PRIMARY COIL TO HSVE THE DOUBKE KICK
A FLYBACK OR IGNITION COIL  FOR THE RECOVERY PATH
GOOD IDEA ON SHARING RESULTS GOOD AND BAD
NAYBE WE CAN PUT A SUMMARY AND LOOK BACK ONCE AGAIN
PREVIOUS POSTS JUST STARTED IT
somebody  can copy paste   if time allows them
Mine using  sg  ignition coil relay spark gap to e core produced 340 v open v ac  but output limited only to 40 w  led bulbs
Others can share here also
cheers
