ENERGY AMPLIFICATION
Magluvin
Wow Nieve   That is a huge setup in front of that house.  The neighbors must have been terrified.  =]
Hey Teets.  Ok, that point was sharpened, and thanks.   Modules?  Ok well thats the first I have heard that from you. But you had termed it another way before.   But modules are cool.
Im a bit lost here but will keep on truckin.  =]   I did have a question, but as I wrote this, I decided it was invalid. =[
I had tried the 2 diodes on a load off of the end of a secondary as shown above, and nada.
Not at high freq, but as the article said, that low voltage and freq could be done also, I didnt get anything.
I thought about it for a bit as to how current could flow through the load in this config.    Lets say a positive or negative phase caused current to flow through 1 diode, through the load, and back out the other diode back into the same wire. I suppose it could happen, like a single wire cable can send multiple signals at once.  But I see the open ended secondaries charge at the time to work against this, in my mind.   hmm   I have some ideas that I want to try to see this effect, so back to the bench.
I hurt my heal today from stepping on a rock the wrong way, and its hurtin.  Im guna get some rest.
I have been desiring being able to put up some vids. I enjoy doing them. But they need some good content.
Man I wish I didnt have to work so much and be able to get more done here. Im trying to give a lot of attn here, but with the move and my brothers bad attitude here, I have to put this aside quite a bit.  Once Im settled, I will have a greater amount of time to think properly also.
My brother is being prescribed aderal and 2 whole zanex each day from a doctor that should be put in prison.. and also a half gal of vodka a day.    It is very hard to deal with him in any fashion.  But Im out of here and wont have these types of distractions.  I pray.  =]
Mags
Tito L. Oracion
Quote from: ramset on October 20, 2010, 09:48:30 AM
Tito,
Quote,:
AND SHOULD ALWAYS BE AVAILABLE TO USE.
Does this part mean a battery?
{meaning a battery is VERY important for this]
Chose one.
1. yes
2.No
Chet
Yes in one of my setup, i actually using one 3v button cell.
No in one of my setup, cause i'm using stubblefield or two different metals or galvanic battery.
No again in one of my setup cause i'm using antenna as source.
all in all battery is still much better to use cause it is stable and reliable. and small  ;)
Tito L. Oracion
modules is a set of procedures and function to do some task, that when i go back there it do some gain of at least 1/3 of the power used but because we return a lot of times until a reservoir is full then that's it.  ;D
There should be a validation if it is time to continue or not yet  ;)
Perfect Timing is always needed cause in basketball throwing and throwing are useless if they are not point counted.  ;D
or in assassination, the subject must be there before throwing a bomb.  ;D
;D
forest
Tito
1. multiple hose have to be special filled or air ?
questions about Tesla igniter
2. high self-induction coil surely have iron core
do we use it:
a) to push a roundabout
b) as a wire
3. I'm using 9V battery to push roundabout, is that able to lock to correct cron timing or is better 2a
ramset
Mags
I can Feel the torment in your posts,It upsets me because I know how powerless you feel about your brother.
I went thru a simular time in my life ,when I was like your brother,there is no escape from the torment in a pill or a bottle,been there done that!
Tell you brother he really can make the rest of his life the best of his life!
I will mail you my # and would be happy to share my experience with him!
Keeping you in my prayers,
Chet
PS
@Mags and ALL
If your not watching this you should be
http://www.overunity.com/index.php?topic=7833.new
400%  ---2700% overunity
independently varified!!!
And Thane, boom boom, Cranky pants, Zilla
Is available !!
I must be dreamin??
Thanks Grandma
