ENERGY AMPLIFICATION
Magluvin
Thanks Ram   I appreciate that. ;]
Teets!    So some of the tips you are using programming dialect to describe things.  That helps.
Roundabout = flywheel ?    ;]
Timing.  Can it be automated, or triggered for accuracy according to the operation, or is just fine tuning necessary?  Do you use micro controllers?  PIC
Thanks Teetla.  These things are very helpfull. ;]
Mags
Magluvin
Ram
That is interesting on the transformer.   What if you have 2 toroid cores side by side and looped them together with a primary, then put the secondaries on the outer side of each core, could it do the same?  It might be very simple.
But maybe the cores would have to be shaved to mate with each other to look more like and 8 rather than 00, just from what I see that he has the primary on a much leaner core than the secondary.  Thinkin.
Thanks for the good show. =]
Mags
ramset
All Data On
Thanes device,just posted here!
http://www.overunity.com/index.php?action=downloads;sa=downfile&id=443
@ Mags
Good to see your Cracking the "Teetsla Cron frozen ice balls Code"
Teets You better be nice to Mags!
Or I'll B&*$t  Y#$&% R&*%) in the eye!
Chet
Thanks Grandma
Tito L. Oracion
Quote from: forest on October 21, 2010, 01:39:50 AM
Tito
1. multiple hose have to be special filled or air ?
     No: there is no special filled or air; just use them naturally but they
            should be made in an efficient way.
questions about Tesla igniter
2. high self-induction coil surely have iron core
do we use it:
it depends actually, we can use them for boosting volts and current, its up to us what we want to increase.
a) to push a roundabout
b) as a wire
c) as a dissipater at the same time
d) for strong kicking also
e) all of the above  ;D
3. I'm using 9V battery to push roundabout, is that able to lock to correct cron timing or is better 2a
sorry i don't much get your question or how you make your timing.
First and formost is how you use your source, it must be used in efficient manner and in half life only.
Tito L. Oracion
Quote from: ramset on October 21, 2010, 02:01:58 PM
All Data On
@ Mags
Chet
Don't worry i'll be gentle honey  ;D
