ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
Magluvin
Quote from: Google on April 10, 2014, 08:34:31 PM
Here is a link from our German host Mr. Stefen Hartmann : Thanks Stefen.
http://www.overunity.com/12109/tpu-revolution/#.U0c2sX1X7MI
:D
Hmm.   http://www.overunity.com/12109/tpu-revolution/msg314408/#msg314408
"The driving coil have two opposite windings."
We have all seen where 2 coils are wound on a tube or air core, 1 wound in 1 direction, the other wound in the other direction bothe meeting in the middle. Utkin pdf   ;)
"Take for primary multiple-core cable 0,7-0,9мм isolation must be fluoroplastic."
Will have to look that up, 'fluoroplastic'
"Take 2 fluoroplastic wires each lenght 4,2м. Wind both together - bifilar winding (end of first wire to begin of second. This is for primary."
Ok. Tito did say bifi primary. ;)
"You need to wind in meters not in turns."
Otto said something to this effect, cutting the coil wire length, snipping of bit by bit till tuned. ;)
This fluoroplastic wire with 'cores'  Is that a wire with a plastic core with the wire running on the outside of the core with plastic insulation? Possibly could use coax cable? Or copper tubing? ;D
Seems very coincidental. ;) Tito mentioned using coax once or twice.
Ok, gota eat and shower, then look up fluoroplastic wire.
By the way. I like this Google better than what was going on before. ;) can we keep it that way? ;D
Mags
Magluvin
Quote from: a.king21 on April 10, 2014, 10:37:53 PM
The Kiker 2004 patent.  Now where have I seen something like it before,
I wonder hmmmmmm?
Nice catch on that one. ;)   The other pat shows just a battery, coil and motor. So I think it is possible to be used at lower voltages? ???
Mags
Google
Yes Magpie it will go on this way only....to the goal.  ;D ;D
Copper tubing man, copper tubing core.... ;) ;)
Gigolo ;D
a.king21
Kiker: They've done a lot of research on this on energetic forum You would be as well to read up the reports.
When I read them bells went off.
They were using it in their water spark plug experiments and other stuff.
However.....
I can now report that based on their anomalies, the use of the large tubed helix generates a
.... STATIC FIELD!!! and the energy comes from electrostatic induction.
This deduction is based on HV experiments in their spark plug tests.
Marsing
gig, where do you find that scematic ? more info ?
http://www.overunity.com/6763/energy-amplification/msg396831/#msg396831
aking21,
http://peswiki.com/index.php/OS:Chris_Brown%27s_KML_Coils
Chris Brown's Own Measurements Show No Change In TV Setup - Last week, Chris reported that he had run a television on a KML Coil system he devised, and that the duration seemed much longer than what would be possible without the KML Coils. Today, his first before/after control test concludes that the KML Coils are not contributing anything to the system. (PESWiki; April 23, 2009)
