ENERGY AMPLIFICATION
0 Members and 64 Guests are viewing this topic.
Dave45
  • Quote
  • Voltage amplifier – This is the most common type of amplifier. An input voltage is amplified to a larger output voltage. The amplifier's input impedance is high and the output impedance is low.
  • Current amplifier – This amplifier changes an input current to a larger output current. The amplifier's input impedance is low and the output impedance is high.
  • Transconductance amplifier – This amplifier responds to a changing input voltage by delivering a related changing output current.
  • Transresistance amplifier – This amplifier responds to a changing input current by delivering a related changing output voltage. Other names for the device are transimpedance amplifier and current-to-voltage converter.[/quote]
http://en.wikipedia.org/wiki/Amplifier
This I believe is a current amplifier, I rearranged the circuit a little it resembles Akula's 80 watt device.
I know Iv heard his devices are fake and may be, its the working principle Im after.
Dave45
Look at Don Smiths device what if the primary was not the primary, actually the primary could be used as a feedback coil to trigger the gate of a fet but the fet would drive one coil, hmmmmm hard to put in words let me draw it up.
I labeled the coil as the primary because thats what its been called but in this circuit its actually a feedback coil.
This is just an idea havent went so far as to test it yet just thinking about the possibility's, could this same principle be used in Kapandze's coils.
edit: I forgot the diode
Google
Dave,
Have you ever wanted to build a UFO?  There's been allot of work based upon the polarization of dielectrics and or space.  But, I had this idea.  Since, a parallel tuned circuit stores energy and a series tuned circuit shorts it out, even though both are resonant, the thought of transmitting with a parallel resonant circuit at ultra-high voltages millions of volts, and receiving with a series tuned circuit all of that energy does produce a directional result.  From one antenna to the other in an almost quenching fashion.
In electrostatics you learn that 3 million volts is where the dielectric of anything breaks down and a plasma is ignited or an arc.  Positive or negative can blow directionally.  It's all a matter of whether the positive charge has built up above a ground potential or the negative.
So, if you have a floating potential, it's all a matter of where it wants to go quantitatively. So, if you have a parallel resonant circuit with a transmitting antenna and a series tuned receiving antenna, they'd pull or be attracted to each the other.
So, building a basic high voltage motor that will spin based upon the two different circuits being mounted on a single dielectric post should prove the point because it could be driven at a distance away from a Tesla coil.  If the parallel tuned circuit leads and you have a basic air core solenoid, and a basic solenoid based series tuned circuit both tuned to the same frequency as the Tesla coil, they should rotate in the direction of the parallel tuned circuit.  You want enough distance to try to prevent mutual inductance, even though it is impossible, try without using more than a ground plate as a shield.  Don't box them in so that they cannot resonate.  Even with those balanced on a piece of string from the ceiling could prove a point.Matching impedance with the permeability and permittivity of space may seem impossible.
But, if it's ever really done, you could use everything that allows for a photon to travel across space as if it were a stationary rail in space pointed in any direction you want to go.  If effect use space itself as a key component in a linear motor.
Nikola Tesla's work appears to shine when I look at it. Much of todays knowledge does not. I don't understand why this is but I hope to get to the bottom of this.
A couple of things shine brighter than others but seem to have gone un-noticed by others.
Do these things not shine to anyone else?
ElgooglE
Dave45
Space travel doesnt interest me much Im going to do that when I leave this world if God will let me and I wont need a ship.
But free energy to pump water for gardens and heat homes of the poor interest me very much that is my goal.
Jeg
In an older experiment where i was hunting to catch Tesla's radiant effect, i had accomplished a collector which was working in the following way. Tesla had said that if the Cap discharge happens very quickly, then this radiant energy is moving so fast that wire by itself can not hold it. So it leaves the wires in a perpendicular direction. Trying to catch this effect, i had put the primary of a normal tesla coil inside a copper tube with a spiral shape so to make space economy (with no electrical connections between them ). During the discharges a hv electrostatic potential arises at the copper tube's walls, capable to light neon lamps. It zapped me many times but didn;t kill me. It pains a lot though!
My best game with this setup was to attach an AWG 40 thin like hair wire to this copper tube, and light a lamp 10 meters away of the setup. The lamp was lighting brightly only when i had it in my hands. I also did Moray's trick, to light it by interrupting the thin wire line with a piece of glass. And of course i light it like Gray, by having the bulb in a bucket of water. I stopped this experiments before manage to collect this extra energy to a an other cap.
