ENERGY AMPLIFICATION
Magluvin
Hey IWD
Very good IWD.  So you have tried the precharge circuit and confirmed it that the inductor(flywheel in motion), does continue to charge the cap beyond the source, due to the collapse of the field, and shows no signs of BEMF, Reverse emf nor counter emf, just forward emf and when dissipated to the cap through the diode comes to rest.
This is important to understand. It defines the ability for the inductor to act as a flywheel.  Add a cap and the flywheel is offset, the weight of the flywheel is offset, to represent a pendulum action, as this video uses the comparison also.
http://www.youtube.com/watch?v=vKjUzsNj8NM&feature=fvw
This vid demonstrates a way to kick the pendulum at the proper time to follow the oscillation naturally, "nature timing" as Teets tips.  =]   And Forest gets credit for this find.  =] Thanks forest and Teets.  Good Guys.  ;]
Now, I cant be sure yet, but I have a notion to believe that we may be able to keep the flywheel(inductor) going by Kicking it also. I dont know if Teets or anyone would agree, but its a notion or theory.
But this vid above sort of says a lot, according to what Teets Tips say to us.
Iwd, if you wish to go any further or try and expand upon the precharge circuit, please do. I will once I get settled here, err  there, Im not there yet. lol
I try to get back on here at OU as much as I can for the time being. I just leave the laptop on all day with the page ready to read or reply.
Mags
Tito L. Oracion
Quote from: forest on October 23, 2010, 03:26:57 AM
Tito
I think you are talking about "ring twice" version as a second one ,right ?
No. i'm talking about one small kick then a controlled spontaneous action begins.
the first one is the ten watts cap into thousands and thousands convertion.
i thought we got it already.  :(
i actually discovered another one but just little similarity with the first one
"The multiple caps with the same volts but unlimited"
To open the door to unlimited source of energy we just need to have a hot  tripillar coil.  8)
don't worry i am now planning to show a vid of mine, and i am the actor ;D
;D
ramset
HA
I knew it!!
Teetsla's A movie star!!
So Handsome------->>>>>>> ;D
Chet
Thanks Grandma
IWD
To mags
Well I am sorry, I was misunderstood what you want to confirm. If You want to understood the coil as flywheel so be it, but that already show Romerouk on many pages before.(diode acros pulsing coil) you can cleary see it by osciloscope conected on that coil when you decrease space betwen pulses (betwen kicking) the flywheel will rotate more, so also negative spikes will be more powerfull, bigger voltage. When you place diode as romero, or as is in relay, the curent in coil will also flow more, because inertia  of current have way where can flow(flywheel can rotate)
Point is that in both case take more current from battery.
And Polarity of the coil is always changing, in feeding you can measure on coil tension from source, and when source stop, then you can measure tension from inertia in coil+colapsing magnetic field, both have same direction, so seems that is changed but it is relative from where you measured it beacause direction of current remains same. (direction of flywheel remains)
Only when you have secondary, then on it is changed polarity and also current direction.
"There is always many ways how to look on same thing" for example if you will listen a japanese man talking about physics you can listen about year and you will do not udersnatd. But if he show to you a pictures and schemes then you will quickly understand (pictures can be more than thousand words)
And when someone is trying to explain his discovery in his way of understanding. And even more...if he cover it by fog of his own puzzles like Tito do. Then nobody will really understand. But there is a video promise, so mabybe we se the part of Clothes from story of  "Emperor's New Clothes" which reminds my this situation here.
Magluvin
Hey IWD
Many do not know this about inductors. Read this recent thead, the first post, as Chris claims that the collapsing field is what creates the reverse emf, or flyback. But its not so, as you have pointed out that you already know this.    http://www.overunity.com/index.php?topic=9875.0
There are possibly many thousands of people watching this thread, some who want to learn because they are beginners.  Everyone needs to know the way things work. Some here at OU may not have known this and until they do, they may never understand every way to use an inductor.  Heck, up untill recently, I thought that the field collapse is what caused bemf, just like chris explained it.  Even if the books back then probably described it the way I now know it now, but we were told things as we were learning it that had us thinking otherwise. Why would that be? Everyone I knew back then came away with the same understanding as chris, and I, thinking that the collapse caused bemf .   Did you know before you read Romerouk?  =]
Mags
