ENERGY AMPLIFICATION
0 Members and 144 Guests are viewing this topic.
Google
Google
Errors in the theory of Electricity and Magnetism
http://www.bearsoft.co.uk/ErsEM.html
Google
How to change the magnetic flux ??
1.  Change the dimensions of the shape through which the magnetic field passes to adjust its area. Because the flux is equal to the magnitude of the magnetic field times the area through which the field passes, increasing the area will increase the magnetic flux and decreasing the area will lessen the flux.
2.  Determine the direction of the magnetic field. If it is a small enough field, such as the field produced by a refrigerator magnet, sprinkling some iron shavings on a piece of paper will reveal the direction of the field lines. If the field is induced by a wire, use the right hand rule to find the field direction; that is, point your right thumb in the direction of the current and curl your fingers. Your fingers will indicate the direction of the field.
3.  Change the angle of the area with respect to the magnetic field lines. Shallow angles between the field and the area are accounted for in the magnetic flux equation by multiplying the field strength by the area by the sine of the angle between the field lines and the area. If the area is perpendicular to the magnetic field lines, the flux will be at its maximum.
4.  Change the magnetic field strength. This is the equivalent of increasing or decreasing the flow of water through a hose. If the field is made from an electromagnet, you can increase the current running through the coil or increase the number of coils to increase the magnetic field.
Google
This post is dedicated to David.
Dave45
This post is dedicated to Google  ;D
