ENERGY AMPLIFICATION
0 Members and 333 Guests are viewing this topic.
DimaWari
@totoalas,
Obserbahan ko pa sir.. kakainstall ko palang sa house di ko lam kun makakasave ako... But some show their e-bills and its zero!.. nkakabilib diba?
totoalas
Quote from: DimaWari on May 03, 2014, 12:01:04 PM
@totoalas,
6666
i will buy  today  obly 188 pesos per pack od 10 sachets
will try also if not successful then we can drink the coffee instead  please update me and share yr findings  thanks 8)
Bob Smith
Hi Everybody
I read this last night while reviewing the thread. I think it has some important info.
Bob --
Quote from: Qwert on February 20, 2013, 04:24:25 PM
I guess I have solved one Tito's secret. Sometime in the past Tito mentioned that in his invention he uses a solution found in Tesla's Ozone Patent. Till now nobody seems to get, what exactly Tito meant.
In the post under this link
http://www.overunity.com/6734/real-ou-effect-to-share-with-everyone/msg206661/#msg206661
Tito gives an answer to a guy (FatChance!!!) who states a specific point of view:
"Simply because there is no overunity to be had from discharging a capacitor into a coil.
What you believe as overunity, is actually performed in everyday modern electronic devices.
I'm talking about the switched power supply. This is discharging a capacitor into a coil and
then stores the coil Bemf in the output capacitor. And there is no overunity what-so-ever.
In the best case, the switched power supply can reach 99% efficiency when using the best
components available, aka low ESR capacitors, LOW Rdson mosfets and the finest coils with
low resistance, very low hysteresis and eddy current losses.
All cases showing overunity while discharging coils or capacitors is always underunity.
Any overunity reports is just a clear sign of a person lacking the necessary measurement skills.
Tito's answer: "hi FC
try to study the ozone patent and your belief may be change ok
I guess, Tito's essence starts at about 85 verse, page 1 of the patent original text (patent # 568177):
"Around the controller is formed a circuit of low self-induction, which includes a condenser L and the primary M of a transformer. The circuit including the motor is of relatively high self-induction, and this property is imparted to it by the coils of the motor, or, when these are not sufficient, by the addition of suitable choking-coils, so that at each break of the motor-circuit a current of high electromotive force will be developed for charging the condenser, which may therefore be small and inexpensive. The condenser discharges through the circuit which is completed through the brushes G K and the controller H, and since the self-induction of this circuit, as well as the capacity of the condenser itself, may be given practically any desired value the frequency of the discharge-current may be adjusted at will.  The potential of the high-frequency discharge-current is raised by a secondary coil N in inductive relation to the primary M."
Here is another link with relative subject:
http://www.overunity.com/7941/tommey-reeds-pulse-generator-output-test-update/msg197620/#msg197620
" Hi tom good day
how did you made your PWM?
i mean how could it last the switching on and off?
And answer, just two posts below:
Otits,
The pulse generator is design so the kick back effect wont destroy the mosfet.
Think of one way valves, power goes in, and the kick back (or say fly back), goes into the cap.
If you add a diode to a coil, the fly back is shorted out to prevent the mosfet from being zap from the high voltage kick back.
I use 4 diodes for that reason, but add a cap into the center of the 2 diodes to collect the back emf.
Tom.
Also, I found very important this link (innovation_station):
http://www.overunity.com/7513/creating-free-energy-out-of-collapsing-magnetic-field/msg184532/#msg184532
go and read it.
and this
http://www.overunity.com/6763/energy-amplification/msg202694/#msg202694
"what i'm saying is, as i am studying tesla's different kinds of patent, i concentrated most in this patents:
a) U.S. Patent 0,568,178 -
b) U.S. Patent 0,568,179 -
c) U.S. Patent 0,568,180 -
d) U.S. Patent 0,577,670 -
i've read also the teslas interview what forest's is posting in this subject
and i come up in a very simple solution when i combine bearden and bedini's technology.
sorry buddy i cannot give my circuit yet but  i'm telling you the truth.
the only thing that i did not give is the arrangement of the circuit. ok its an rlc.
DO YOU KNOW THAT USING THIS METHOD CAN GENERATE KLWATT FROM A 1.5 VOLTS!
ofcource sub-staging technique must be used ok. "
I'm just reading these patents; right now I can only say that patent # 568178 is about setting resonance in a circuit.
I'm continuing to track Tito.
Bob Smith
Sorry guys - last post today. I came across this schematic using a zener and the poster talks about the possibilities of a big return thru avalanche breakdown. Please have a look. It's simple, but do you think it speaks to what we're trying to find here?
See: http://www.overunity.com/6763/energy-amplification/msg352846/#msg352846
Bob
Qwert
Hi.
This may be somewhat important at least for some of you:
there is a Tito's post which refers to another info but this post is just misspelled and leads to nowhere
(Re: Lords of the Ring
« Reply #1 on: January 07, 2007, 06:39:15 AM ») - this is misspelled, there is no such address.
I've just corrected it.
Here is this Tito's post where he gives a link to the misspelled post (lords-of-the-ring):
http://www.overunity.com/7513/creating-free-energy-out-of-collapsing-magnetic-field/msg184535/#msg184535
and here's the correct(ed) one:
http://www.overunity.com/1872/lords-of-the-ring/msg21437/#msg21437
this post is pretty long but it's worth to read it, at least looks like Tito concluded that. Unfortunately, most links in that post don't work anymore though they did at the time of the year of 2009. (That was the reason that Giantkiller left this site).
But, one link, still alive, can be quite important, it's about flyback xformers:
http://www.repairfaq.org/REPAIR/F_flytest.html#FLYTEST_006
