ENERGY AMPLIFICATION
0 Members and 131 Guests are viewing this topic.
Tito L. Oracion
Quote from: forest on November 01, 2010, 03:43:02 PM
Tesla patent 462418
"First if a condenser or conductor possessing capacity be charged from a suitable generator and discharged through a circuit , the discharge under certain conditions will be of an intermittent or oscillatory character"
can someone enlighten me about "CERTAIN CONDITIONS" ?
That would allow me to convert one inductive kick into many capacitive kicks ,right ?
And I'm not cheating ...I really do not know what Tesla named as "certain conditions" but I feel it is crucial to have working device. Well, maybe he said about disruptive discharge ? Interesting indeed.
Later he said that there is of tremendous advantage to break at the peak of wave and again that may be related.
Hi! brother forest how is the jungle?  ;D joke
Let me give you something what i understand about CERTAIN CONDITIONS.
In computer languages like in C programming there are certain conditions before a procedure or a function will execute or a certain task will execute, So we have to validate some what material to use, if made of material is efficient, if components are balance and if they are in right place then if these conditions were met correct then its always 'right time' to do that task.
There is a tremendous advantage to break at the peak of wave, YES! because if you break at the peak, the secondary will be ENERGIZE at that peak  so there is a tremendous gain in there. and that is also part of some CERTAIN CONDITIONS.
;D
Magluvin
Well  Im breakin out the box of goodies for the evening.  I am eager to try some things, moving or not. =]
Here is a vid I did a while back using reeds and coils to make an oscillator to boost voltage Caveman style to run Agent Gates coil.
http://www.youtube.com/watch?v=vOMzSpPHFo0
But I am going to use it to charge a cap, and the cap voltage is stepped up every oscillation till max cap charge is reached.  If you watch the vid, the small yellow cap on the breadboard is being charged from the oscillator through the 2 blue caps then to the bridge rect.   The small disassembled relay coil on the bread board, has resistors in series so that the coil does not fire the reed till the yel caps voltage reaches about 30 to 35 v. Then that reed dumps the cap to the transformer primary. This setups source was 5v.
Now what I will attempt is to use 12v on the oscillator to get over 100v into a cap, and a dpdt relay, with contacts in parallel to decrease the resistance for the cap dump (should last twice as long as a single contact), and use the same method to activate the relay as in the vid.
Just gota give it a shot.  Wish me luck.   The transformer I will use is a 110v to 12v center tapped out.  I am going to try both directions to see what we can see.
Another thing, this transformer is from a UPS for pc power.  It has multiple conductors on each leg of the 12v side.
After tests as is, I think I can separate the leads to make that side of the transformer bifi.  Is it worth the try?  =]
Should have at least some pics later. Just getting things I need setup. Only to tear it down tomorrow, maybe. ;]
I cant get away from this stuff.
Mags
Tito L. Oracion
Well, well, well, that's exciting, goodluck, good day, goodnight, and goodbye  ;D
Congratulation  everyone !!!!!
it's me Tito L. Oracion From
Philippines Now signing off Bye  ;D
Magluvin
TEETS!!!    Why byby teets?    why not HiHi.   :P
Mags
Tito L. Oracion
Sorry i have to drink my milk first my mama is signing off  ;D
:P :P
;D
