ENERGY AMPLIFICATION
0 Members and 46 Guests are viewing this topic.
forest
and also Diag 6, search for it... plenty of tips in this Tesla interview...
 instead 50 Watt some Units more f.e. :  http://www.pulstar.com  with "1000000 Watt compact" burst
                           force field energy density by capacitor/-s,but really decisive ?
Sincerely
               OCWL
and this technology as e-magnet source and introduced f.e. here: http://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=4345174A&KC=A&FT=D&ND=3&date=19820817&DB=EPODOC&locale=en_EP
makes a Pulse Motor
from the Angus motor/engine description
The operation of the inventive engine 10 will now be described. It is first to be noted that the pull of an electromagnet varies as a function of the area of the holding surface muliplied by the square of the flux density divided by a constant. Also, that the flux density increases as the distance to the holding surface decreases. Hence, changes in the flux density is the greatest contributor to the pulling force of an electromagnet. Experiments conducted by the inventor have shown that an electromagnet powered by two "D" cell batteries can produce a holding force of 500 pounds and that the magnetic attraction force varies with the distance between the surface of the electromagnet and the item to be lifted. It was found, that at a distance of one-eighth of an inch, the force is approximately 7.8 pounds; at a distance of approximately one-twelfth of an inch the force is 31 pounds; at a distance of approximately one/twenty-fourth of an inch the force is 125 pounds; and, as stated, at contact, the force is 500 pounds. Thus, a usable force begins when the distance is one-eighth of an inch and increases rapidly thereafter.
                                             But is HV and/or HF really a need ?
                                               from the same "description":
As an alternative, to retain plate 25 against piston 24, plate 25 is made from a magnetic material and electromagnet 24 is energized by a low voltage during the override portion of the stroke.
                                                      No,there is not a need !
Cadman
Quote from: forest on May 08, 2014, 05:03:07 AM
Forest can you post a link to this particular interview, or the diagram? All I can find are excerpts with no diagram.
Thanks
Cadman
Just an observation here
Tito posted info on various different devices he was experimenting with. I think we should make an effort to separate the different stages of these to minimize confusion. To me it seems like there are several separate stages involved, each mentioned at different times.
1. Collection of ambient energy to begin the amplification process, which is optional.
2. Amplification, a true increase. Chemical, carbon spark gaps, other? Also optional.
3. Frequency amplification, not optional.
4. Return energy to the starting point of the process.
That being said, Tito always encouraged us to learn the processes involved and create an original work.
stupify12
http://www.overunity.com/14134/forward-emf-collection/msg401660/#msg401660  Diagrams in words.
Quote from: Cadman on May 08, 2014, 10:05:22 AM
