ENERGY AMPLIFICATION
0 Members and 44 Guests are viewing this topic.
Dave45
Quote from: Bob Smith on May 25, 2014, 08:33:07 PM
Dave,
There used to be a guy who was setting up oscillator circuits using npn and pnp transistors. I looked for his YT channel for a long time, but couldn't find it.
A couple of thoughts about your charge separation proposals:
It occurred to me that within a single stranded coil, say on a hollow core... is not one end of the winding going to be north and more relatively positive than the other end (relatively negative and south)?  If this is the case, could charge separation be just a matter of isolating each end of the coil - say the secondary on a HV transformer?  I'm thinking specifically about the Tesla Hairpin Circuit. You've got a HV transformer, spark gap in parallel with secondary, then one cap in series on positive and one on negative leg.  Finally, your light across the 2 legs is lit up brightly.
If you watch the video I posted a couple of pages back, the guy mentions the air around the hairpin circuit as "the dielectric."  But is it not just the aether? And is not the oscillation and charge separation exciting the electrostatic environment (aether) to access its energy?
If you substite a cap for the spark gap and keep the inline caps, do you not have charging a cap in parallel, then discharging in series for charge separation?
Bob
PS Ice cream was good :)
Edit: from 2 pages back:
Interesting
Iv read some that say the energy we use to pulse a coil is not the energy we get back, the energy we get back comes from the environment, in other words all the energy we put into a transformer is used to pulse the transformer and the energy that comes out the other side is from the ambient.
Im not sure I agree with this but it is interesting to think about, I will rule out nothing until the answer is found.
I believe the magnetic field and electric field are two separate entity's for lack of a better word, if the energy we put into a coil only builds the magnetic part then the ambient must be furnishing the electric part.
For every action there is an equal and opposite reaction
We need the reaction to be be greater than the action, for that to happen we need a source, we have to ionize the magnetic field.
When the sun releases a solar flare the earths magnetic field is ionized and becomes very energetic, if the earths magnetic field were to collapse after this ionization ,,,,,,,,,,, well it would not be pretty  :(
The hairpin circuit seems to be pulling energy from the ambient but only equal to the transformer causing the displacement,
We can build an ionization circuit that takes milliamps to run, or they can be had already made in air purifiers and ozone generators.
I pick them up at thrift stores for cheap, cheaper than I can build them.
Dave45
Why does a cloud with ice have more lighting strikes than those that dont.
Iv played with the ice its a perfect dielectric, I believe the ice in the thunderstorm rises and falls cutting the magnetic field lines of the planet as this happens the ions are stripped from the magnetic field lines charging the water droplets.
Its storming here in Texas today,
Dave45
Rainy day  :D
Baby sitting my three year old granddaughter  :D
wished I were in my shop  :(
forest
in both example capacitor is shunt by dead load...can you explode when cotter is in place ? when you expect great  explosion  when you are tired of hard work ?  ;D ;D ;D
Magluvin
Quote from: Dave45 on May 26, 2014, 10:40:30 AM
Rainy day  :D
Hey Dave
I believe those 2 circuits operate the same. The switch and inductor position change as shown should still provide the same throughout both circuits.
Been thinking about what Teets said. Length of wire, not number of turns.
Saw a vid once, or a tv show that was talking about nano measurements. I believe she said 1 nano second for a signal to travel 8 or 9 in wire length. Otto wrote about cutting little bits off the end of a coil to tune. So if we just wind 500 turns on 2 separate but same cores, they may not really be the same as each other.  Like if we tested the 2 coils in some idea we were working on, are we missing out on the goods by not fine tuning like Otto did?
Just got in from working on my shop.  Been busy.
Mags
