ENERGY AMPLIFICATION
0 Members and 96 Guests are viewing this topic.
Bob Smith
Quote from: Dave45 on May 31, 2014, 10:14:07 AM
http://books.google.com/books?id=Er3i0Q5w53UC&pg=PA31&lpg=PA31&dq=choosing+a+power+diode&source=bl&ots=s-eKO28nlK&sig=WJHILiN3LvgsYvg_VQo1ksH2qEA&hl=en&sa=X&ei=EsSJU4HIL4KaqAbS9oH4AQ&ved=0CF0Q6AEwBjgU#v=onepage&q=choosing%20a%20power%20diode&f=true
info on diodes, including zener's
Thanks very much Dave. I read it a few times; it's quite rich. I'll keep it bookmarked.
Our Zener discussion really spilled out about 8 pages back, around here:
http://www.overunity.com/6763/energy-amplification/5700/#.U4n8krlOWpo
I've been reading back thru the posts.
Here's my basic sense of it in light of Larskro's schematic (& video) and what's been discussed here:
The zener allows the voltage to run normally in the circuit, but with the inductive kickback, allows the voltage to travel back in order to add power to the circuit.
Teets specifies the zener, and Weisisky noted that all that's needed is coils, triode (to pulse, I think) and a zener.
So you get the push-pull-push-puull from your voltage spike and kickback (or kick-kickback-kick-kickback-kick-kickback).
In this way, you loop the radiant energy kickback that comes back thru the zener into the initial circuit, ringing up your coil, producing a standing wave.
It's just a matter of picking it up.  As Teets says, balance is key, because your resonant and pickup coils have to be balanced to resonate with the first coil.
I hope this helps with the discussion.
I still see room for the charge separation issue here, as we're using I think what Dave has referred to as FEMF and BEMF. I think it's a matter or pulling it all together.
GTG
Bob
Magluvin
Quote from: Dave45 on May 31, 2014, 07:38:25 AM
Very nice description, and your right it doesnt really matter to a resistive load but it does matter to the inductor.
Mags
The boost converter and buck converter are well known and used in the electronics industry one boost voltage at the expense of amperage and the other boost amperage at the expense of voltage.
I have my own idea's about how they work and show them in my diagrams.
The sims are set up in the conventional view if you go to options and uncheck conventional view the sim will run in electron flow view.
I dont think any circuit by itself will go ou, it always pulls from the battery, you may boost voltage or amperage or both but you are always pulling from the bat.
We have to have a source other than the battery, whether it be radiation from radioisotopes or another form.
I believe ionization is the key, an ionization circuit builds a neg ion cloud around the pos electrode and a pos ion cloud around the neg electrode.
What I think happens in an ionization circuit, the electrodes cause a stress on the aether (the air) pulling the molecules apart into pos and neg particles, these particles can be collected using a magnetic field.
Hey Dave
Here is a good book I own that you should buy.  'regulated power supplies'  Irving M. Gottlieb
Also 'Simplified design of switching power supplies'  John D. Lenk
Both are excellent reads.  ;)
The position and orientation of your diode is mostly why the 2 circuits are the same.  The changing of the power switch position makes no difference at all, as shown. Neither does the changing of the position of the inductor as you show. Series circuits such as these components(switch, inductor) are in, makes no difference in circuit operation when changing their positions as shown. ;)
There are also many sites on the basics of buck, boost, inverting circuits.   ;D
Mags
ALTECHLAB
Brazilian terra GEN by Barbarossa/Lea, Kapagen, self-support models...possible here in update and upgrade version: www.altechlaboratory.com
official test (DVPR, EFEMA) and re-engineering for mass production and installation.
Lab models and prototypes is available...
Farmhand
ALTECHLAB, lets talk straight, do you have devices for sale that output more electrical energy
to a useful load than the energy that is input to said devices ?
Of course not.
QuoteAlTechLab is a very early-stage startup that is currently searching for seed funding for this particular project. AlTechLab has a history of project development utilizing 3D design and a rich electrical engineering talent base associated with plasma generation and plasma reactions. AlTechLab is currently seeking $52,700 in seed funding for the development of the proof-of-concept advanced charging system bench top prototype. Once successful, AlTechLab plans to raise an additional $320,000 in funding for a large demonstration prototype unit that can charge an electric vehicle.
AlTechLab TEAM Yuri Rybchenko - AlTechLab owner and team leader... more information by request:
e-mail:  altechlab1@gmail.com
Nick Moroz-Consultant, Ann Arbor, MI
Olek Alekseychenko - Sr.Developer from Yazaki Corp., Canton, MI, USA
Andrey Krischenovich - TET Lab owner and in depended developer from Ukraine
Keep your wallet firmly in your pocket.
