ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
d3x0r
Quote from: Dave45 on June 01, 2014, 11:25:54 AM
thinking out loud - load  :D
then you're open to receiving comments from the loud peanut gallery.
It should be noted that when dave indicates red and black he's referring to two different currents... the electron flow doesn't reverse in a collapsing single field.   It would be easier if he used a single notation to indicate either electron flow....
Again, a collapsing field doesn't reverse the current, so it must be that he's using two different notations for the same thing... to make it seem like it's reversed.
Farmhand
Yeah a ram pump would work but the output would be surging I think. Going by the flow from his hose he has more pressure than the mains water pressure here.
Dave45
Quote from: d3x0r on June 01, 2014, 12:02:54 PM
Iv come to think of it more as pos and neg polarity's at play within the circuit.
They could be considered voltage and amperage I guess but pos and neg is more acceptable.
a.king21
Quote from: that_prophet on May 31, 2014, 01:19:20 PM
it is simple
you put a small amount of power into a big pulley
which you only have to rotate once -(minimal power)
and you can rotate 10 mini pulleys 100s of times
YOU SIMPLY MUST GAIN AC ELECTRICITY
WRONG. WRONG WRONG.
There is one one major factor you are forgetting. (I've done the experiment).
When you put ANY LOAD on any of your generators a PHYSICAL resistance to movement is created.
This will slow down the whole series of pulleys.
Qwert
Hi.
This guy {that_prophet} appears around this forum on numerous threads since several years already. I found that he/she presents lack of knowledge of basic principles of physics and also lack of understanding, stubbornly repeating his/her always the same idea. What more, that guy wants somebody to build a contraption based on this sick idea, probably because he/she is somewhat physically retarded; his/her behavior of stubborn recurrence without any sign of learning conclusions of such relatively simple idea shows also some mental retardation.
So, my conclusion is that any effort to convince this guy just to learn some basics is just IN VAIN, this guy is unable to digest that.
