ENERGY AMPLIFICATION
0 Members and 56 Guests are viewing this topic.
a.king21
Quote from: that_prophet on June 02, 2014, 03:38:27 PM
oh yah, it takes soooo much torque to turn a 100 cm circumference pulley
+ three 10 cm circumference pulleys
this works, please build it
it is so simple to build
we can change the world
http://free-energy.yolasite.com/
this is a Gift from our Father in Heaven
Please take Jesus into your heart and become Born Again NOW
(the generation that shall not pass, will pass before 2020)
http://doorschristmustpassthrough.yolasite.com/
If you would like to know where this one_christian_warrior is coming from
Please view http://beliefstoliveby.yolasite.com/
If you would like to know where that_prophet is getting to
Please view http://fire-starter.yolasite.com/
The problem is not in turning the pulleys. The problem is that once you put a load on a generator,  a force opposite to the electrical energy you take is created which slows the whole pulley assembly down. So any  electrical output results in physical braking of the device. The volts may be there but you cannot extract the power for free.
If you put a 100 watt bulb on the generator, a hundred watts (at least) is created in opposing torque.
a.king21
Tito: That's better.
Now, how about some real clues....
Please......
Tito L. Oracion
Quote from: a.king21 on June 02, 2014, 09:47:40 PM
Please......
OK, We don't actually need spark to the real thing , and to eliminate it, we should be working in low voltage and since electricity is symetrical we divert it to make it safe but we transfer a lot.
let say for example: to control the movement of a very high speed ball bearing is to place it in a circle path way as its speeds diminish little by little and that is the principle of yin and yang.
long time ago we need a spark and a spark gap but its not actually a good idea.
Marsing
Quote from: Tito L. Oracion on June 02, 2014, 10:22:24 PM
Change spark gap with Transistor, and i thought you have said those many-time, what you didn't say is "Congratulation, you have found jt".
Tito L. Oracion
Quote from: Marsing on June 02, 2014, 11:20:08 PM
Yes, we could do it in high voltage but i am making everyone to go into a path of safe.
but if you feel you are tesla like then proceed to 50,000 volts design its okay but its dangerous.  :)
