ENERGY AMPLIFICATION
0 Members and 58 Guests are viewing this topic.
Tito L. Oracion
Quote from: Farmhand on June 17, 2014, 02:32:54 AM
The problem is almost always in the difference of definitions of key words like power and energy, some people interchange them often some people only occasionally and some never. There are times when either power or energy can be used for example if we say the input is 1 watt for 1 hour we are talking energy but stating it with a power over time statement.
Also we can say the output is similar.
When problems arise is when people confuse the way the person intended the statement to read, no matter how it is written.
Also with translations power and energy may be mixed up.
Basically output energy is in Joules total or Joules/watts over time.
Input energy is in Joules or Joules/Watts over time.
Input and output power can be stated as 1 kw in and 2 kw out but with no mention of time it could be 1 kw for 1 hour input and 2 kw for 10 seconds output, obviously the input is less power than the output but the output is less energy than the input in that case.
Also sometimes people do make mistakes and say energy when they meant to say power.
If the Linked machine was OU then we would have seen a demonstration by now and if there is no demonstration, then someone saying it will output more energy than input should build it and show the extra energy. Whats to fear when it's already patented.
And claiming MIB BS is just ridiculous because when people claim to have OU they ought to be running the same risks as showing it, and take the same precautions. But no one is scared to say they have OU unless they actually did have it.
SO if Tito actually had OU and he believed in the MIB angle he would be too scared to even say he had OU. Logically people that claim to have OU but won't say how to get it because of MIB fears are full of BS because if they were in fear of the MIB they would not even say they had OU.
The MIB line is a cop out, if you have fears of the MIB then don't say you have an OU device because if you do you will draw suspicion. It's contradictory and contradictions means, things don't add up.
Tito should Marry Zilano, they are almost identical, or would he be marrying him/herself. hahahaha  ;D ;D ;D
Sheez Louise.
YOUR BRILLIANTLY FUNNY. :D
So you mean you don't believe on MIB's,  :D  so you don't have a news about some killed inventors? hmmmmm :o
You are very expert about energy and power description, but it seems that you don't know law in marrying. :D :o :P :P :P :P ;D ;D ;D
OFF THE POPCORN!!! >:(
a.king21
Calm down Tito. Your tips are welcome. :)
Peace.
Leely
I've noticed that if u pulse the sec side of a 220v - 24v volt trafo with a 12v 7ah battery using a relay, the back emf can even burn the wires. I tend to believe that the trafo converts it to high current low voltage. What do u people think?
Reiyuki
  Maybe it helps if we look back to the path Tesla was on, before the Colorado Springs experiments.
Tesla: Notes on a Unipolar Dynamo
http://www.andrijar.com/teslahom/
  He was interested in unipolar/Faraday generator, and for good reason.  Instead of relying on changing fields, this generator produces power from a difference in reference frames, not by coils at all.  It is an electrostatic generator, one that instead produced few volts with amazing amps.
  So, in essence this generator uses a 'pressure difference', a difference in relative velocities, to generate power.
  What if we could make this pressure difference without spinning the disk at all? ::)
I think Tito's devices work by creating these virtual pressures and harvesting power like a Faraday generator (short, thick wire).
Cheers all,
Rei
d3x0r
Quote from: Reiyuki on June 18, 2014, 12:33:27 PM
Cheers all,
Rei
doesn't matter if the magnet rotates...
http://www.animations.physics.unsw.edu.au/jw/homopolar.htm
