ENERGY AMPLIFICATION
0 Members and 25 Guests are viewing this topic.
ramset
Teetsla
Quote:
Tito mateti reporting  ;D
Good to see you happy!!
I hope we can get this?
make some heat! It's getting cold here!
The water's freezing and Chaloopa can't wash cars anymore
Chet
Thanks Grandma
Magluvin
Quote from: forest on November 10, 2010, 03:00:21 AM
Questions: how we can shift phase of electric wave ? I have to move it forward by 90 degrees for example . I would explain it later what I'm trying to do
Forest.   You can use a transformer 1 to 1  and use the secondary in phase or out depending on which way you hook it up. Or you can design a filter network that would pass the freq you want, depending on the level of Db per octave cutoff, as in 1 cap in series with a speaker is a high pass at 6Db per octave, and 1 coil in series with the speaker would be lopass at 6db per octave. Now a cap in series then a coil across the speaker will be 12Db cutoff, the add another cap in series after the coil, 18db,  another coil across the speaker, 24db.
Db per octave is just an eaxample, but each one, 6, 12 ,18, 24 will apply a different phase to the speaker in reference to the source.  I will have to look it up, I cant remember which is 180 deg out of phase. But thats another way to reverse phase, passively.
Mags
Magluvin
Quote from: Sprocket on November 09, 2010, 07:38:29 PM
Seems I'm easily confused, are these bi-filar or ordinary coils? -  the guy doesn't mention bifilar at all!  And his description at the end is less than clear - why didn't he just state the battery voltage & current for both setups.  Also, with regard to the link I posted, that guy states that a bifilar-wound coil (double the wire length, so twice the resistance) will result in a doubling of the magnetic field (the way he winds it, it doesn't!), whereas your guy states that quadrupling (or times-eight if they're bifilar) the length results in only a doubling of the magnetic field...
At least it's good to see a working example of an increase in magnet field when the coil resistance also has increased.  Of course I have yet to figure out how to wind a coil that displays this myself...
That vid was done for me personally to show his progress.   He had proven to me that each time he added a coil in series, windings that were all on 1 bobbin wound simultaneously,  the resistance went up and the field was stronger. Quadfi. I was debating it with him for a bit as to how he was hooking it up, but he knows what he is doing..
All we can do is try.  In that article you posted with the nail electro magnets, I have not tried that yet either, but Im going to.   The explanation as I understood it, both nails have 100 turns total, but 1 is 2 x 50 bifi, so the load on the source should be the same, but increased mag field.  As for the self capacitance, could it be that the initial currents are increased as compared to normal winding, due to an empty self capacitance and a decreased inductance?  But when using dc as the source, I imagine the mag field being the same once the coil is fully charged and currents are the same for each nail.  It needs investigating.
Mags
Goat
@ All
I have a circuit that will run an NE2 (neon lamp) for a sustained amount of time off an AA battery, the NE2 usually runs from 50 - 90 VAC so what can I do to "amplify" the AC off the NE2 to ~ 1.5 VDC back to source?
I must admit that at this point I haven't tried a feedback mechanism in order to not damage the input circuit.
I thought of feeding the 2 leads off the NE2 to a transformer and/or capacitor and then back to input but how to do it eludes me.
Any ideas from anyone to come up with a feedback circuit would be welcome.
Edit: I forgot to mention that the circuit will sustain the NE2 for a few minutes after an initial charge.
Regards,
Paul
Sprocket
Quote from: Magluvin on November 11, 2010, 06:18:38 PM
Mags
The debate about this 'technique' seems like it has been going on for years.  What is frustrating is the number of people that turn up, allude that it does indeed work - then leave it at that!   Annoying in the extreme...
I guarantee that if you do build the 'nails' experiment as instructed and use DC, it will not work!  So the first question I ask, why is a web-site which purports to be honouring Tesla's achievements knowingly peddling false information?
One of the things that is often mentioned by those that say this is viable is that it works with AC only, with no other info forthcoming...
