ENERGY AMPLIFICATION
0 Members and 560 Guests are viewing this topic.
                     3,6 KWh = drei komma sechs Kilo(=1000)Watt/Stunde
=             3600 Wh = 3600 X 1Wh = 3600 X 3600 Ws = 12.960.000 W/s
in words :  twelfe millions nine hundred sixty thousand Wattseconds
        compressed energy
       from  upper     " direct=gleich Strom/stream/current/flow/Fluß " per second  conditioning
                                                              to :
                      pulsed     direct=gleich Strom/stream/current/flow/Fluß
             Crisis/Kreis          Frequenz,     Hertz,Swing/Wave        Impulse per
            What is expressed exactly with Hertz?
Hertz is the physical unit of frequency. The European electricity grid is an AC power with a frequency of 50Hz. This means that the current one hundred times per second, changes its direction. The daily flow which brings up and running such as a lamp to light or a motor, has 50 Hz ln Europe are matched all electrical equipment on this frequency. If the actual frequency deviates too much from 50 Hz devices do not function properly or no longer after all. This can happen when the demand for energy is higher than the amount of electricity that is provided by the power plants. TenneT ensures that a balance between the consumption of energy by the end consumer (electricity demand) and the supply of energy by the power plants (electricity supply). Thus, the frequency of about 50 Hz remains constant and the equipment is functioning properly.
                                                         50 Hz                     100 pulses
                                                         60 Hz                     120 p.
        better,clearer :
                                                         50Hz/s                   100 pulses/s
                                                         60Hz/s                   120 pulses/s
ergo:                                       Dirac surges as 1 actio pulse (Europes 50Hz) :
   3,6KWh = 12.960.000 Ws linear DC =
   12.960.000 Ws/(100 pulses/s)
                 translatory(wechselnder/alternating/changing) DC
                 rotatory [kreisen(der)/cruisin(g)/drehen(der)/rotating/circulatin(g)] DC
                                                  or AC
    DC/DC       DC/AC     AC/AC   AC/DC              trans-/tele- formation
-----------------------------------------------------------------------------------------------------------------------------                    the Coloumb load/Ladung capacity of 100 pulses / s(ec) =50 Hz
                                              compressed in one Hz  = 0 or O  kreis(linien)Welle
                                              + EMP                 -EMP
                                     obere                    untere               Kreis Halbwelle
                                     upper                    down                 circle half wave
                                   +(pos) amplus         amplus-(neg.)   circle half wave
        mit dem  Zirkel sollte man umgehen koennen !
                                                ::) :)  physical designing  ;)  Bye-Bye B'B'
Sincerely
              OCWL
                                                 http://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=8711619U1&KC=U1&FT=D&ND=3&date=19871119
a.king21
Quote from: Qwert on July 09, 2014, 10:35:19 AM
To my knowledge, "60" stands for frequency; voltage is somewhat different.
I was referring to the British Telecom telephone wiring voltage. The info was given to me by a retired BT engineer. I don't know the HZ but I'll ask him.
Bob Smith
Quote from: Jeg on July 09, 2014, 04:37:20 AM
Thanks Forest for one more great source for reading!
Bob, can you please make a screenshot of page 62 of Tesla's interview on High Frequency high currents?
Tesla: ''... the damped wave is of advantage because it gives you with a generator of 1 kilowatt, an activity of 2, 3, 4 or 5 kilowatts.....'' If this is not a clear statement of OU what is it???
Jeg,
Great page selected!
Quote62 Work With Alternating Currents
Counsel Speaking of your not having perfectly undamped waves at that time, you were referring to that character of circuit?
Tesla Yea, but with another kind of circuit I could, of course. The advantage of this apparatus was the delivering of energy at short intervals whereby one could increase activity, and with this scheme I was able to perform all of those wonderful experiments which have been reprinted from time to time in the technical papers. I would take energy out of a circuit at rates of hundreds or thousands of horsepower. In Colorado, I reached 18 million horsepower activities, but that was always by this device: Energy stored in the condenser and discharged in an inconceivably small interval of time. You could not produce that activity with an undamped wave. The damped wave is of advantage because it gives you, with a generator of 1 kilowatt, an activity of 2,000, 3,000, 4,000, or 5,000 kilo-watts/ whereas, if you have a continuous or undamped wave, 1 kilowatt gives you only wave energy at the rate of 1 kilo-watt and nothing more. That as the reason why the system with a quenched gap has become popular.
I have refined this so that I have been able to take energy out of engines by drawing on their momentum. For in-stance, if the engine as of 200 horsepower, I take the energy out for a minute interval of time, at a rate of 5,000 or 6,000 horsepower, then I store (it) in a condenser and discharge the same at the rate of several millions of horsepower. That is how these wonderful effects are produced. The condenser is the most wonderful instrument, as I have stated in ny writ-ings, because it enables us to attain greater activities than are practical with explosives. There is no limit to the energy which you can develop with a condenser. There is a limit to the energy which you can develop with an explosive.
A common experiment, for instance, in my laboratory on Houston Street, was to pass through a coil energy at a rate of several thousand horsepower, put a piece of thick tinfoil on a stick, and approach it to that coil. The tinfoil would melt, and would not only melt, but while it was still in that form, it would be evaporated and the whole process took place in so small an interval of time that it was like a cannon shot. Instantly I put it there, there was an explosion. That was a striking experiment. It simply showed the power of the condenser, and at that time I was so reckless that in order to demonstrate to my visitors that my theories were correct, I would stick my head into that coil and I was not hurt: but, I would not do it now.
I couldn't post a screen shot, but got an OCR conversion of it and quoted it above.  Here's the URL to the book:  http://www.tuks.nl/pdf/Reference_Material/Aetherforce_Libary/Aether%20Mage/Nikola%20Tesla%20-%20On%20His%20Work%20With%20Alternating%20Currents%20and%20Their%20Application%20to%20Wireless%20Telgraphy,%20Telephony,%20and%20Transmission%20of%20Power%20(Leland%20I.%20Anderson).pdf
I wonder if the secret in this page is simply pulsing a number of parallel wires which dump into the same cap. As Tito said, "the manyer, the better."  Any thoughts?
Bob
a.king21
[quote ]
Bob
[/quote]
I think you've got a point here.
I'm currently charging nine batteries with one spike generator hmmmmm.
Tito L. Oracion
Quote from: Bob Smith on July 09, 2014, 02:10:06 PM
Jeg,
Great page selected!  I couldn't post a screen shot, but got an OCR conversion of it and quoted it above.  Here's the URL to the book:  http://www.tuks.nl/pdf/Reference_Material/Aetherforce_Libary/Aether%20Mage/Nikola%20Tesla%20-%20On%20His%20Work%20With%20Alternating%20Currents%20and%20Their%20Application%20to%20Wireless%20Telgraphy,%20Telephony,%20and%20Transmission%20of%20Power%20(Leland%20I.%20Anderson).pdf
Bob
;)   :) :o    ???
