ENERGY AMPLIFICATION
0 Members and 156 Guests are viewing this topic.
Bob Smith
A few observations that I find to be shedding light on Tito's energy amplification - the core amplification principle:
Bob
QuoteThe key to the Stanley Meyer fuel cell lies in the "Tesla Choke" that uses "Tesla's Regenerative Effect" to effectively recycle charge by recycling the Back EMF of each + pulse to add to the next + pulse. This regenerative effect in resonance essentially cascades the input charges to 1000's of volts greater than what you actually input...
QuoteI didn't invent this method of recycling charge, neither did Stanley Meyer. The Tesla Choke/Meyer Voltage Intensifier Circuit is really Tesla's "Electrical Igniter for Gas Engines" patent no 609 250 of August 1898. This has been classified for more than 100 years and was only ever used in Fords original Model T. Since then the capacitance/inductance resonant effect was removed from the ignition coil that we have today.
Remember when Mr. Teslonian dug out that quote from Tito saying he had found the "secret" to energy amplification in this patent?
Here's a link to it:  http://www.teslauniverse.com/nikola-tesla-patents-609,250-electrical-igniter
QuoteRetards think cascading charge to 1000's of Volts is impossible. An analogy is pulse a coil & collect the Back EMF & store it in a capacitor then add this stored energy to the next + pulse to double the power output.
    I merely do this 1000's of times per second, this is called fractioning & involves storing that recycled energy in a ferrite core to be added to the next + pulse at resonance. This is how a Tesla coil recycles charge- I merely use the Tesla Regenerative effect to power my Fuel Cell.
QuoteBack EMF is captured on the Tesla Choke because of a blocking diode and is stored as flux on the ferrite core to be added to the next + pulse.​
Source:  http://open-source-energy.org/index.php?topic=1153.0
Bob Smith
More info related to the above quotes, taken from one of the poster's YT pages. While it is laid out for WFC use, I believe the energy amplification principle can be applied to Tito's apparatus, the elusive Titonium ;D ;D ;D
QuotePublished on Jun 4, 2013
  The WFC v1.0 software is Stanley Meyer's original software given to the Maori's in New Zealand from when Meyer went to NZ to share his technology. I used to give this software away on the net and teach people how to calculate and dial into resonance.
You can make your own Tesla Choke using a 20mm cardboard tube. You just wind 2X 190 turns of 5/10mm (Magnet Wire #24). The polarity of L1, L2 is very important as L1 must cancel out the Flux of L2.
There's a picture in one of the slides on Stanley Meyer's Denver presentation that I'd uploaded in my video's.
Tesla Choke
• At LC resonance the positive pulse goes through blocking diode to the positive Tesla Choke.
• Positive pulse hits one side of the bifilar Tesla Choke coils.
• The Tesla Choke coil becomes NORTH charged at the end the diode is attached.
• The positive pulse hits the positive outside tube.
• The positive pulse hits the water.
• The positive pulse potential hits the negative inside tube.
• The positive pulse potential hits the other Tesla Choke coil wire connected to the negative tube making that end NORTH.
Both Choke coils are wrapped the SAME way on a ferrite core. Stanley Meyer's diagrams clearly show that the positive choke has NORTH at the diode end of the positive Tesla Choke and the negative choke has NORTH at the Tesla Chokes opposite end.
The most important aspect is that these fields with NORTH at each end of each of the Tesla Choke coils are that they are in polar opposition to one another, thus restricting current flow to the fuel cell. The Tesla Choke both restricts magnetics (current) to the cells and cascades back-EMF voltage spikes to very high potentials. Also the blocking diode prevents any reversals of current flow which prevents arcing from taking place within the cell. The system is actually series-resonant, so the output voltage is limited only by the Q of the system (by the resistance of the wires in the resonator coil).
Another way is we could just use Tesla patent 593 138 to transmit power and step the voltage up at the transmitter end, then step it back down at the receiver end. Rather than using only a step-down transformer in the receiver, instead we use a hi-Q resonator, and we allow the resonant voltage to rise to a very high value. As a result of this, massive amounts of EM energy will be "sucked" into the receiver and use this energy to power our HHO cells or sell power to the power grid.
Source:  http://www.youtube.com/watch?v=mwK7mYIpjkM
Bob Smith
The Zener Effect
With the application of sufficient reverse voltage, a p-n junction will experience a rapid avalanche breakdown and conduct current in the reverse direction. Valence electrons which break free under the influence of the applied electric field can be accelerated enough that they can knock loose other electrons and the subsequent collisions quickly become an avalanche. When this process is taking place, very small changes in voltage can cause very large changes in current.
Source:  http://hyperphysics.phy-astr.gsu.edu/HBASE/solids/zener.html#c1
