ENERGY AMPLIFICATION
0 Members and 95 Guests are viewing this topic.
forest
example about bad simulation circuit
$ 13 4.9999999999999996E-6 85.40587625261516 79 5.0 66
178 288 160 288 272 0 1 0.06 -0.007126811817257538 0.05 1000000.0 0.02 30.0
w 256 160 288 160 0
v 96 256 96 176 0 0 40.0 12.0 0.0 0.0 0.5
w 96 176 96 160 0
w 96 160 240 160 0
w 96 256 96 288 0
w 96 288 304 288 0
w 304 288 304 272 0
g 480 288 480 336 0
c 528 160 528 240 0 1.0000000000000001E-7 9.999974470326222E-4
d 432 112 528 112 1 0.805904783
w 288 160 288 112 0
w 288 112 432 112 0
d 432 112 432 288 1 0.805904783
w 432 288 480 288 0
w 480 288 528 288 0
w 528 112 528 160 0
w 528 240 528 288 0
w 528 112 608 112 0
162 608 112 608 288 1 2.1024259 1.0 0.0 0.0
w 608 288 528 288 0
o 9 64 1 299 7.62939453125E-5 9.765625E-5 0 -1
o 2 64 1 299 1.25 9.765625E-5 1 -1
replace LED by a neon (I didn't found it in falstad simulation tool)
in reality it works fine ! ground is my worktable with large iron vice
I can charge 100nF 630V capacitor to 90V in split of seconds so neon across it is lit continuously.Current is taken from iron ground ???
forest
another circuit variant in that one I was able to charge cap only to 20V :-(
I believe that Avramenko plug is scattering radio waves into DC pulses but look how two diodes are used. I think they produce opposite pure voltage potentials but they are shifted in phase (positive pulses and negative pulses)
I believe that with shifting negative pulses to be at the same phase as positive will make this current pump work twice efficient due to larger voltage difference between capacitor terminals.
Remember it is slow frequency car relay powered by 12V input source !
Now you tell me how to replace relay with higher frequency higher voltage circuits ???
forest
forest
exercise :
take two AV plugs with long wire and place nearby , try to visualize how we can connect both together  ::)
IWD
Quote from: forest on November 14, 2010, 07:07:29 AM
Nice teory If you want seek complicated things, where are not.
If you wonder how avramenko work. Just imagine membrane pump, like this
http://www.e-cerpadla.cz/ftp/images/vererair.gif
If you rise frequency (rate of pumping) or voltage (pressure) you will have more efective pump, that is true. When you applied something like both pulses, negative and positive, you will get nothing.
If you wonder how to rise effeciency, just go study stiffler device
http://67.76.235.52/images/seccir.gif
http://stifflerscientific.com/
He already sucessed with that, when applied about 200v spikes with frequency about 3mhz, realy effective pump.
