ENERGY AMPLIFICATION
0 Members and 271 Guests are viewing this topic.
a.king21
Search for TITO-NIUM !!
HAhAhA 8)
Dave45
What do all the Russian devices have in common.
They have a Tesla coil wound first, an ionization coil.
Look at all the Tesla coil experiments where an led or any bulb for that matter is lit along the side of the secondary,    exactly where the Russian's are winding there pickup coils.
The Tesla coil builds a strong electric field in this area, and if the ends are left open they ionize both ends of the coil.
Look at Tesla's ionization circuit, the coil configuration.
Dave45
A little added benefit we have that Tesla didnt,,,silicone diodes.
Just have to be careful about ionization points where the wire is connected to the diodes, smooth solder joints with shrink tubing.
MarkE
I can't see any justification for diodes at both ends of the same coil.  One at either end should be fine.  Just make certain that it can handle the voltage that the winding produces as connected.
Dave45
Thanks Mark for your helping input, your comment made me look at the reasoning.
The reasoning behind two diodes
If we look at a full wave bridge, in my understanding, a coil pulsed with ac has both pos and neg pulses on each end of a coil.
If only one diode is used the end with the diode will stay either pos or neg depending on the diode's orientation but the other end will receive both pos and neg pulses which will cause the ions on that end to join back together since both pos and neg ions are being formed.
A full wave bridge may work better but the half wave may cause tension in the field being only half is being rectified.
