ENERGY AMPLIFICATION
0 Members and 25 Guests are viewing this topic.
Dave45
This is not an insult but you are so ingrained with what you were taught you have lost all common since, a capacitor does not pass current it acts like a spring bouncing energy back through the circuit.
You are highly educated but need to start thinking for yourself, there's no telling what you would come up with.
All the best
dave
Dave45
Quote from: MarkE on July 21, 2014, 11:08:04 AM
Dave the diodes in the output sections of both of those circuits are part of voltage doubling networks.  During one half phase the capacitor attached to the transformer secondary charges through the vertical capacitor.  During the opposite phase, that capacitor discharges through the horizontal diode into the output capacitor.
In electronics, the term "filter" means "frequency selective network".  The diodes in your example do not function to filter energy on a frequency dependent basis.  They just pass current based on the direction of potential imparted across them.
The way I see it the neg energy is bounced back and forth through the secondary while the pos energy is allowed to exit through the diode----pos ion gen
The opposite is true for the neg gen.
Dave45
Can free energy be had, can it be understood.
Not by conventional physics
But is very simple if you understand
A coil pulsed with pos energy gives back neg energy
A coil pulsed with neg energy gives back pos energy
What does that mean
A boost converter uses an npn transistor to pulse a coil with neg electrons and the return or bemf is pos, higher voltage.
http://cdn.makeagif.com/media/7-13-2014/zLW9Hh.gif
A buck converter uses a pnp transistor to pulse a coil with pos energy and the return or bemf is neg, higher amperage.
http://cdn.makeagif.com/media/7-13-2014/cySfvR.gif
This breaks no laws is not pseudoscience, its based on the law of attraction and repulsion of like and unlike charges.
So why isnt a buck boost converter overunity?
In most if not all buck boost circuit's the same coil is used.
Lets look at static neutralizers, they use the same principles.
A static neutralizer is just an ion gen that uses two electrodes to ionize the air, both electrodes are placed in close proximity to each other and the work surface to be neutralized, the charges are separated and recombined in a small area effectively neutralizing any static on the work surface.
The same is happening with the buck boost converter's that use the same coil, the coil is ionizing the air around it but because they are using the same coil any charges are being neutralized.
Two separate coils must be used, They must be separated.
Dave45
For every action there is an equal and opposite reaction.
The coil is pulsed with pos or neg energy and gives back an equal but opposite reaction.
To get more from the system than is put in the coils need to be ionized using a separate ionizing circuit.
The ionizing the coils create is proportional to the energy being applied.
Give the coils something to draw from.
If the coil is in and ionized cloud it has a source to draw from that is greater than the energy applied.
MarkE
Quote from: Dave45 on July 21, 2014, 11:56:29 AM
All the best
dave
Dave if you misuse terms then it becomes very difficult to communicate.
For all practical purposes a capacitor "passes" AC current even though the dielectric prevents charge from passing plate to plate.  In the instant case, charge is drawn to the plates of the horizontal capacitors in one half of the cycle, and driven from the plates in the other half of the cycle.  Undulating current can be measured anywhere in the loop consisting of the:  transformer secondary, horizontal capacitor, and vertical diode.
