ENERGY AMPLIFICATION
stupify12
I recommend it to you guys, used JFET your efficiency will greatly improve when we are talking about counter emf. The inductor should we wound with a adjustable core, a core in a inductor is really needed to achieve the Tesla charging choke.
Meow
Quote from: Dave45 on July 26, 2014, 11:16:00 AM
Of course we dont want to forget the open ended bifilars  ;)
Dave45
Quote from: stupify12 on July 26, 2014, 11:31:39 AM
Meow
Agreed it increases self inductance, which you want collecting bemf.
Thanks
I'll add it to the schem.
Quote from: Dave45 on July 26, 2014, 09:19:42 AM
Of course, the open end allows the coil to draw.
Like an antenna.
A source besides the battery.
Drawing energy from the ambient.
Thank You Mr. Tito
                                                             Space-Time
                                 ambient~ (RF) aether ~ Hyperraum/Hyperspace  -Hypertime
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=41&ND=3&adjacent=true&locale=en_EP&FT=D&date=19860717&CC=DE&NR=3501076A1&KC=A1
> The conventional physics so far knows only the real components of electricity, magnetism and gravity. In order to describe interactions in the form of vibrations and swirls between the aforementioned variables, however, it requires complex quantities. According to recent theories must be assumed to exist in our space and imaginary magnitudes, from the premises under certain transformation known forms of energy is possible in us.
> Using the above hyper-energy theory is meant by ferromagnetism alignment unpaired electrons (there are small hyperspace vortex) in order to establish a resultant vector field.
> In this orientation, the mirror-image spin axis positions are equivalent to positive or negative remanence, stable and real. Similar to electronic semiconductors sufficient in ferromagnetic semiconductors, a pulse with low energy for folding.
> Plant and machinery that use the hyperspace as an energy source, are no perpetuum mobile, but energy converter in the conventional sense.
> The energy of hyperspace is taken in equal quantities, eventually converted into thermal radiation, returned to hyperspace.
> The law of entropy, which presupposes the existence of two memory for energy conversion cycle process is adhered to. The first, probably inexhaustible for us humans memory is the hyperspace, the second memory and at the same time converter in conventional forms of energy, a magnetic core.
Object of the present invention is the utilization of cached in a magnetic nuclear energy for industrial purposes by conversion into electrical energy or mechanical work. The pulse magnetization is to be understood here in a figurative sense as a kind of valve control between the outer hyperspace energy storage and the magnetic core buffer.
In this case, the relation pulse duration tp, the time duration of a half cycle period z / 2 a decisive role. The reciprocal size is in the computer core memory technology as a Pulse duration duty cycle v = tf t to the pulse width defined.
0 The case tp = tz / 2, which in electrical engineering, for example, corresponds to the sinusoidal field concatenation of the primary and secondary winding for transformers and electrical machines, requires a larger internal losses to the primary-side supply of energy can be delivered as the secondary side. The converter efficiency must be less than one.
The case t <t / 2 sets to achieve a aftereffect effect, counter-pz set to tp = tz / 2 the use of magnetizable material with Speicherei oxy-afters, so with pronounced hysteresis loops ahead. For this purpose there is in the signal processing and computer technology, a variety of suitable materials. They were used in large quantities for ferrite ring cores in memory matrix framework some time ago. The requirements of data technology of magnetic core memory other than ån memory for energy technology. It is with a minimum of field strength of the envelope of the positive remanence (information content "one") to the negative remanence (information content "zero") erfolgen.Für energy technology, a magnetic core as much power as to be taken out as a product of current and voltage at the is, however, a significantly larger field strength for the envelope of the residual induction is necessary. The coercivity of the magnetic core material is the magnitude of the permissible back ampere and thus the purpose of energy deprivation before allowable current, however, the generated by cargo or commutation induction swing determines the inducible voltage. The product of current and voltage should be as large as possible. Thus, a material is needed for a power magnetic core memory, the area enclosed by the hysteresis Ummagnetisierungskurve is as large as possible.
Dave45
As no one here seems to be interested we'v decided to build the circuit here http://www.energeticforum.com/renewable-energy/19556-sssg-osc-variations-bedini-2x-plus.html#post261301
Please join in the build, if nothing else we are going to build one heck of a DC to DC converter, and who knows maybe push it over the top. ;D
MarkE
Dave,  I think as the circuit is drawn you are at high risk of blowing up MOSFETs by excessive gate to source voltage stress.  I need to think about how to fix that without making changes that you probably would not like.
