ENERGY AMPLIFICATION
Can someone please tell me, just in one simple paragraph, what this circuit is actually supposed to _do_?
stupify12
Dave. The circuit is now looking good.  I think it is much better if we utilized only 1 Battery as power source and the other is for Recovery Storage then swap it when you feel to do so. The coils should be wound like the one I have already suggested and shown on this thread which is the same as what Kapanadze is doing on his coils, Kapanadze wound it in a spire/conical fashion as per Tesla stated for best cylindrical form of this coil. You will understand what does this Winding construction does on the circuit- it seems like it boost performance when loaded, or we should say it nullifies the counter magnetic induction-which is lenz.
Why did I suggest JFET? This is the only electronics component that performs almost like the Vacuum Triode Amplifier. Vacuum Tubes or Spark gaps is the only Electronics component that I know that performs really great in achieving our goal in the Free Energy devices. We needed a switch that is not in physical contact(Semi Conductor=Semi Close Circuit) to the Coil that is being switch, we need a gap like the Vacuum Tubes does, Spark Gap, and Mechanical Rotary Gap.
Still the Tesla Charging Circuit=Tesla Charging Choke is still the best circuit I know that performs in amplifying the energy input. The Tesla Transformator Winding is the only transformer that doesn't disturbed our input oscillation on the primary side.
Semi Conductor is the reason why people cant really achieve the Free Energy that you are looking, because it is always Semi ON or Semi OFF which doesn't permit the IMPULSE overshoot to be recover and be captured by our storage.
Vacuum Tubes is the perfect switch that I know which still exist as of today. Free energy is only achieve with gap switches.
Meow
Quote from: Dave45 on July 27, 2014, 11:27:57 AM
As no one here seems to be interested we'v decided to build the circuit here http://www.energeticforum.com/renewable-energy/19556-sssg-osc-variations-bedini-2x-plus.html#post261301
Please join in the build, if nothing else we are going to build one heck of a DC to DC converter, and who knows maybe push it over the top. ;D
Bob Smith
FYI Guys
See the original post for Stupify's diagram.
Bob
Quote from: stupify12 on July 15, 2014, 12:55:41 PM
The winding is the same for the Primary , Secondary, and extra Secondary. It is composed of CW and CCW in halves. The circuit used to power the Transformer is a common Tesla Capacitor discharge set up. If Left is Clockwise then both Primary and Seconday on the Left side is wound in layered and direction of winding is CW. If Right is Counter-Clockwise then both Primary and Secondary on the Right side is wound in layered and direction of winding is CCW. The ratio of winding is 1:4- 1 for Primary and 4 for Secondary, you could also try to 1:2.5 ratio.  If you wanted to read it for you self look for the Tesla Transformer Construction on the Tesla Book.
That's all guys 8) I just followed Tesla on his detailed construction of his Tesla Transformer. Attached is the picture for better understanding.
Meow
MarkE
Quote from: TinselKoala on July 27, 2014, 07:24:47 PM
The idea ( assuming that I understand it correctly ) seems to be that if one shuttles energy back and forth through coupled windings enough times that extra energy will enter the system.  It is not an idea I share.  Presently, because the gate drive windings do not reference back to the respective MOSFET source terminals, I expect these circuits to switch poorly and probably overstress the gate-source dielectric.  I foresee many dead MOSFETs.  I have not thought of a solution that I think will be accepted as not altering the circuit in a major way.
Bob Smith
- Say we use a coil to pulse a toroid. The flux goes into the toroid and is picked up by a secondary coil.
- Now suppose we pick up the bemf off the secondary with another coil (wrapped around the secondary).
- Using a diode, we direct the bemf into another coil on the opposite side of the toroid so that its flux goes back to the toroid core.
- Now you've got two kicks hitting the toroid.  These get picked up by the secondary and sent back, and this effect multiplies hugely because you are pulsing the toroid many times per second.
- That's a tremendous amount of kicks pulsing the toroid - in fact you will probably end up with standing waves! :o
- Now, let's put another pickup coil on the toroid to resonate with the secondary, its bemf pickup coil, and the coil re-pulsing the toroid.
The trick will be to keep things in balance. Teets emphasized this.  Looking at the Don Smith Device, I interpret balance to mean balance between coils.  This is crucial to maintaining resonance between the secondary coil, its secondary winding, the redirected bemf coil and the pickup coil.  There must be balance.
I think this is the heart of it.  There are other things to fine tune and add in such stepup coils, the kind of toroid material (i.e., ferrite, wire...), caps, the Tito Twister caps and the manner in which you want to initially pulse.
There is also the matter of the antenna, but that's minor compared to the central principle.
Bob
Edit:  I edited things a little for clarity's sake.
