ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
Magluvin
Forest
I know what you are saying.   Im waiting for some caps to come in.   I tried larger value caps and its dreadfully slow.
Kator
Mainly I wanted to see if the av plug charging the cap had any expense on the input, and it does.
And the expense is very low in my opinion.
I think I can do better with the Igniter circuit, with the right inductor. Thats why I got the large roll of wire. =]
Mags
Magluvin
Forest
The Trisil seems to be the Shizzle my Nizzle. ;]    Foshizzle.
Mags
Magluvin
Got my SIDACs in today, 20  for 12.99
Just ordered 50 TRISILs  as shown in the pdf above on ebay for 32 buck shipped, be here this week.
In the pdf, it shows 4 leads connected to each end of the diode, For an 8 pin DIP I would never imagine as much current handling till seeing this.
Cheap enough for experimentation. Can be put in series to raise the breakover voltage.
Cool stuff
Mags
Magluvin
I have been experimenting with the av plug cap charging.
Im using a SIDAC to discharge the cap into a standard ignition coil primary. Im doing the vid in a bit. It might take time for it to load.
Im pretty happy with the results.   The primary of the coil is 1.25 ohms. The SIDAC is dumping 250v from a .33uf 275v cap.  It is producing a very good spark.
To run one of these coils normally with a 1ohm ballast resistor and points at 12v, the coil can consume 6 to 10 amps, with voltages above 14 when running.  All well above 50w
Here we are using max, 60ma 12v,  750mw using the av plug and a small neon transformer circuit.
I wonder how much power they use in todays ignitions..
Mags
Magluvin
Started uploading the vid   It says there is 50 min to go.  Ill post when its up.
I have to say these SIDACs handle a lil juice.  Peaks.
The Trisil is the shizzle though
I am going to try a couple experiments charging the 1uf 2kv cap using a bridge but with the light in series to limit the current to the boards normal running conditions.  The cap should go to 250 very quick for discharge into the spark coil.  I also wanna try 2 sidac in series for a 500v gap.
I wonder if an AV plug would work in a house ac outlet?    Not that it would not consume power, but wonder.
Back when vids done.
Mags
