ENERGY AMPLIFICATION
0 Members and 219 Guests are viewing this topic.
a.king21
http://www.ebay.co.uk/itm/201019368766?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I haven't measured the voltage. It certainly gives a 2 cm spark with a crack that I assume breaks the sound barrier. But then I only run it on 3 volts normally. I have had no problems with insulation breaking down at all.
If you know of any sites with information about types of spark gap, length etc and their relationship  to voltage I would be very interested indeed.
Dave45
Can we raise the voltage of a buck converter.
Quote from: a.king21 on November 09, 2014, 01:59:05 PM
There are plenty of such sites, google is your friend. Below I reproduce three different tables from different sources. For accurate, calibrated gap breakdown voltages you should use spheres of larger diameter than the gap distance itself; this will give you the _greatest_ breakdown voltage per distance. For other geometries, like the needle gaps most people will be using, the breakdown voltage per distance is much less.  You can see that for needle gaps of 20 mm the breakdown voltage is well under 30 kV in air at normal temperature, pressure and humidity.
I think someone put one too many zeros in that EBay advert; 40 kV maximum is a bit more reasonable for your device but I seriously doubt that it will even reach that voltage. What is the _greatest_ gap it will spark over using needles or large smooth surfaces?
Dave45
Spot on Tito
There are about four or five on this forum that this fits to a T
https://www.youtube.com/watch?v=lKpmdgeF_ho
Always looking for a booger instead of seeing the possibility's
This is a long but good vid
https://www.youtube.com/watch?v=bXtO7McrRIY
You boogers know who you are  ;)
