ENERGY AMPLIFICATION
0 Members and 103 Guests are viewing this topic.
Dave45
https://www.youtube.com/watch?v=hplgrNB0JfI
If the pos side of the cap has a higher pos voltage than the battery will the electrons flow to the neg side of the cap rather than to the battery.
MarkE
Quote from: Dave45 on November 16, 2014, 02:07:18 PM
No.  When the switch is on, current flows from the top to the bottom of the inductor.  When the switch turns off current continues flowing in that direction through the inductor.  When the switch turns off  the current loop through the battery is opened.  It is not reversed.  If you want to recharge the battery from the inductor you need to switch both sides of the inductor, or couple the inductor to another inductor (IE make a transformer) that has a rectified connection to the battery.
Conventional theory tells us that if you do build the circuit with two switches or a flyback secondary that energy will be lost each cycle to:  resistance in the switches, cross conduction in the switches, resistance in the coil, resistance in the wiring, and a small bit of radiation.
Marsing
Quote from: Tito L. Oracion on November 16, 2014, 03:58:35 AM
once again  i want to share this to everyone. :)
https://www.youtube.com/watch?v=lKpmdgeF_ho
In the end we only regret the chances we didn't take.
Take risks : if you win you will be happy, if you lose you will be wise.
Don't die wondering.
A pessimist sees the difficulty in every opportunity.
An optimist sees the opportunity in every difficulty.
Whether you think you can or think you cannot you're right.
You are what you think.
If you don't control your mind, someone else will.
Be strong you never know who you are inspiring.
MAKE TODAY RIDICULOUSLY AMAZING.
YOU ARE CREATOR SUPPORTS YOUR DREAMS.
end.
Dave45
nelsonrochaa
The topic is ENERGY AMPLIFICATION  :)     https://www.youtube.com/watch?v=thFuT4FaLdk
This is power amplification ?
Best rewards
