ENERGY AMPLIFICATION
0 Members and 52 Guests are viewing this topic.
MarkE
Quote from: Dave45 on December 15, 2014, 08:49:57 AM
I guess the washers probably would not work the currents would run in the washers.
Has anyone tried cutting lamination's on a lathe.
The lamination's need to run with the magnetic field with cutouts across the lamination.
Laminations are typically stamped out of sheet metal, and then coated.  If you need something special and the machining time and cost are not an issue you could mill sheet metal stock then debur and coat.
Dave45
It could be done with washers cut in quarters and stacked, might be a long process.
After thinking on it halves would work as long as the path is broken.
Cut em, debur em, spray em, bake em, stack em offset, full washer on each end with bolt through the middle tighten them up,done. solenoid gen core
Tito L. Oracion
Quote from: Dave45 on December 15, 2014, 12:22:56 PM
That's good idea dave.  :D
You made me to think more with this. ;)
Dave45
Im going to start collecting rust.
Rust may be our friend, we need a source of electrons.
Dave45
I missed a step in the process.
Cut em, debur em,lay them out and get a good even coat of rust, spray em, bake em, stack em offset, full washer on each end with bolt through the middle tighten them up,done.
