ENERGY AMPLIFICATION
0 Members and 177 Guests are viewing this topic.
nelsonrochaa
Quote from: forest on January 02, 2015, 06:00:01 AM
one source could be for example small solar panel like those used in garden lamps , connected to original garden lamp circuit or any other oscillator running from tiny currents
the second stage would be low esr capacitor and a second oscillator running on this capacitor charge
the next stage could be a colcroft-walton voltage multiplier again charging a capacitor or a small battery
here you can use Tesla methods, whatever circuit potential you like
the only problem is the source of electrons
that's why they opted to use high voltage
we all know that for a long time, there was an article in russian explaining Tariel device
Hi Forest,
As you say : "the only problem is the source of electrons" no is not a problem because are available on earth.
When the negative voltages are produced on the line output the ground is less negative and more positive that line output , this make the flow of electrons due to the potential differential.
The circuit exciter is only a "pump" and  need to produce  negative voltage . Is possible to charge a cap very fast with this process blinding the source.
The air can supply electrons to.
https://www.youtube.com/watch?v=tDh7Uw5XC_w
forest
Quote from: nelsonrochaa on January 02, 2015, 06:37:40 AM
Hi Forest,
yes, I agree, but from my experience it is still a hard task if you work with low voltage and if you work with high voltage it is easily miss. that's why I pointed to RF transmitter knowledge with resonance. basically it is all radio knowledge used the right way
Bob Smith
Thinking out loud here...
The TMT has 3 coils, as does Tito's setup.
The way I understand it, we're looking at 3 equal coils, to ensure resonance.  The third coil has a different topology to help us pick up the resonant impulses without disturbing the other 2.  In fact coil 2 may have a different topology from coil 1 as well - have to get to the bench and try a few things out.
The way I understand it, we have an antenna (coil) dumping electrical charge into a cap, which discharges through a diode (perhaps a zener); the other 2 coils are appropriately configured and placed to keep the ringing going and produce a standing wave, and to harvest it.
This is a simplified bare-bones kind of proposal. There may be a few added components for the cascade effect; I believe coils can be effectively used (as can caps) for this effect.
Here's a link Tito posted over a year ago about the TMT. Look at 1:15 And on.
I believe the Tito's model uses similar principles, but different layout:
https://www.youtube.com/watch?v=2k2ROmDiX_Q
Bob
a.king21
Quote from: Tito L. Oracion on January 05, 2015, 03:35:31 AM
https://www.youtube.com/watch?v=HmXGOlz4AYQ
https://www.youtube.com/watch?v=YLP5CZLLaG8
https://www.youtube.com/watch?v=1zXsN9z-N_Y
https://www.youtube.com/watch?v=5Ax3lLHkykA
Especially the last video
PEOPLE OF GOD AWAKE!!!!!!!!!!!!!
Yes, God is about to give free energy to the world and those who have been chosen are being attacked by Satan
and refuse to give the secret to the world.
How true.
