ENERGY AMPLIFICATION
0 Members and 52 Guests are viewing this topic.
Cadman
OK, I have found what I was seeking when I came to this forum so..
Here is everything you need.
This is not the only possible way so if you want to ignore me and keep on looking for ZPE or Unobtainium then may God bless your search.
Double dot .. lines are quotes from Tito's posts scattered over the years.
Part 1, Charge:
Tesla patent 568177 fig.1
..it is actually convertion of small kicks into big kicks...
..A FULLY CHARGE CAPS ENERGY CAN PULSE A COIL A LOT OK, INTO A POINT THAT IN THE FIRST PULSE WE CAN CHARGE IT ALREADY
..just in one pulse only ok?
..note: we only need volts to energize a caps
..i want you also to discover the DC way of amplification
This is a small version.
http://overunity.com/3852/tell-the-truth/msg68126/#msg68126
http://overunity.com/3852/tell-the-truth/msg68150/#msg68150
http://overunity.com/3852/tell-the-truth/dlattach/attach/16085/
Tesla patent 568176 fig. 1 & 2
..Lets say we have a fully charged caps, if we make, make/break very fast, the caps will not fully discharge, and we can replenish it and back charge it in just one very fast make/break ok?
..making a ringing effect inside the two caps prohibiting a discharging action from the source, and as it is ringing then a magnification is being done at the other coil.
..Discharge a cap on a very thick wire coiled in a bifillar form is very efficient making a very powerful magnetic field ok.
..P.S. Bigger magwire makes strong magnetic field isn't it?
.. discharge a fully charge capacitor in a very thick wire with tail, this will give you an excess energy and this is the secret!. tail = extra coil.
..technique of using other coil making a kick without using any current from the input and that makes excess or unlimited energy.
http://overunity.com/6763/energy-amplification/msg433628/#msg433628
http://overunity.com/6763/energy-amplification/msg433751/#msg433751
Part 2, Discharge:
Connect to patent 568176,
step 1:
http://overunity.com/6763/energy-amplification/msg435120/#msg435120
..only at peak switching very very little energy is used
..is it not that a bridge rectifier can accept ac that is two different direction electricity combining them into one?, and with the help of a cap, the point of cut is being filled.
..let one arm of the coil be connected already to the cap when charging it so that it becomes more efficient ...
..i used input, and the effect of the input, witch is the output, and redirect it into a normal power amplification method
..and since we know that a diode can permit a current and voltage to pass then why not after the diode lets make a lot of coils but not permitting bemf to go back
..Now, what we want is to eliminate the direct flowing but the whole energy effect is being use by us
..The thing that should be happen is that, as if you are using the source but not actually destroying it but you are using it.
..For every single pulse there should be an accumulation happening.
..like what i already said, battery can solve grounding ok,
..WE ARE ALREADY LIVING IN SEA OF ENERGY JUST HARNESSED IT.
(We are living on a sea of energy: Cadman)
step 2:
..alternately discharge this caps in a transformer
..study the real process or the real thing that is happening when charging many caps of at least 10K uf in high voltage dc and discharging it sequencially in a coil with secondary!
..you are correct all caps are in state of being charge then discharging them one at a time i mean extremely fast ok.
..plus the real output so you get the used energy and the output energy be added then you get excess then make some little charging action to make battery always alive ok.
@forest
..hi everyone here is my simple idea to convert HV into L-Volts
..note : You must know first the highest voltage AND CURRENT that you can get ok.
..many transformer then connect the primaries in series then connect all secondaries in parallel ok thats how simple it is, cause it will act as a single transformer ok
Thanks to all the members who shared their ideas and pieces of their research.
Best Regards
Cadman
tim energy
DON'T KILL MY POLE TITO ...  ::)
tim energy
not kill the dipole mean ... Splitting the positive, right ??
simply explained, take just the positive from a 12v battery and connect to positive on a 12v incandescent bulb, then take just the positive from a 3v battery and connect to minus on same bulb and connect both battery minus's together to complete circuit and bulb will burn with the 9v differential.
tim energy
found this on our neighbor @ energeticforum ....
https://www.youtube.com/watch?v=GtKjKSUhuOw
This actually comes very close to the schematic schown in the above YT video. Just remove C1 and you have the same circuit in principle, except for the secondary where the loudspeaker is connected to and the loads.
The oscillation is determined by the transformer as well as C4, where C3 is just the feedback loop to steer your transistor with. The interesting detail with this circuit is that the power supply is attached to the central connection of the transformer. Since the upper and lower half of the primary is one coil, the current going trough the coil is equal in the upper and the lower half of the primary. So, virtually all current going trough the coil has only one place to go: C4 and thus cannot reach the power supply and therefore no killing of the dipole.
So, IMHO this is a very interesting circuit to play with. If you leave C1 out, you should be able to grab more power out of the secondary then you need to put in in order to keep the oscillation going.
Magluvin
Quote from: Cadman on February 03, 2015, 02:38:42 PM
Part 1, Charge:
Part 2, Discharge:
step 1:
step 2:
@forest
Best Regards
Cadman
One thing I really found interesting was in the links to Tell The Truth thread with Erfinder and IST.  Paralleling the primary and secondary of the mot.
I havnt figured out the hookup on that circuit yet. I think its the first time I had seen that thread.
But other than that, it seems like this could all be much simpler.....
"hi mr. stefan
my name is Tito L. Oracion
   i discover the secret of sm, "its the igniter patent of nikola tesla"
http://overunity.com/5975/stefan-and-newman-motor/msg140489/#msg140489
Mags
