ENERGY AMPLIFICATION
0 Members and 61 Guests are viewing this topic.
Bob Smith
Cadman
Quote from: Magluvin on February 04, 2015, 06:29:20 PM
One thing I really found interesting was in the links to Tell The Truth thread with Erfinder and IST.  Paralleling the primary and secondary of the mot.
I havnt figured out the hookup on that circuit yet. I think its the first time I had seen that thread.
But other than that, it seems like this could all be much simpler.....
"hi mr. stefan
my name is Tito L. Oracion
   i discover the secret of sm, "its the igniter patent of nikola tesla"
http://overunity.com/5975/stefan-and-newman-motor/msg140489/#msg140489
Mags
Mags,
The hookup on that circuit is the ozone patent, although not a real good implementation of that patent.
The igniter patent, ozone patent, and all of the patents for currents of high frequency and potential all have the same operating principal. They use one or more high self inductance coils to charge one or more capacitors. The cap(s) are connected to the primary coil of a high frequency step-up transformer forming an LCR circuit. The relationship of the cap(s) capacitance and the transformer primary coils inductance and resistance is such that the cap discharge through the coil is a high frequency oscillatory one, CR/4 < L/R makes it oscillatory. The high frequency transformer is an air core with a heavy gauge primary winding of few turns with a lighter gauge secondary of many turns, similar to a Tesla transformer with no spark gap. I'm sure you already know this.
That's all there is to that part of the device, with the possible exception of the 'extra coil'.
The main purpose is to generate the high frequency high voltage currents that almost instantly charge the caps in the next stage of the device, where the energy is multiplied.
a.king21
Sir, please bear with my english, i`m not  used to speak for it,
here is what i have done:
                                            just make a little modification ofcourse, i`ve made three parallel coil to the one that become high voltage and put a 3 collector perpendicular to that high voltage and thats it just like a tranformer, it gives unlimited energy and it is very controllable, and by dumping the one collector to the capacitor it becomes self powered, just a matter of on and off relay or reed relay, dont forget to use zener diode at least 3v.
be very carefull, you can accidentally make an uncontrollable voltage that look like a tesla coil.
its fun but very dangerous.
try to make coil combination. there is a little secret here so you just try to discover it ,its very fun but dont forget the danger!!!!!!!!
I love everybody so be carefull anyone.
"if power comes from coil then of course you can power everything just it depends on the design"
do you know that we can also make an efficient electrolysis from this, belive me sir just make a try!!!!!!
Thank you,
Tito L. Oracion (Philippines)
It seems he was working on the Tesla principle of cap shorting through a thick wire primary.  The circuit starts with charging the cap  with a high inductance coil in series.
On cap shorting 2 things happen.
1 A huge cap explosion through the thick wire primary, causing an extreme high voltage in the secondary.
2 A huge collapsing spike from the high inductance coil recharging the battery.
Above is Tito's mod.
a.king21
I appologize sir.
so sorry.
i've read the interview of sm and he says "kick is the secret"
in the first place how to produce kicks? and i've searched the patent of nikola tesla, igniter patent gives all the answer.
using low voltage to high or unlimitted voltage is being produce.
just consider it a little sir.
i just used the basic transformer computation to get the coil size i want.
so theres no really secret here.
don't worry i will not post anything anymore.
thank you
tito.
a.king21
So maybe Tito "toroids" the HV output.  Worth a try
