ENERGY AMPLIFICATION
0 Members and 61 Guests are viewing this topic.
crazycut06
Quote from: Cadman on February 03, 2015, 02:38:42 PM
OK, I have found what I was seeking when I came to this forum so..
Here is everything you need.
This is not the only possible way so if you want to ignore me and keep on looking for ZPE or Unobtainium then may God bless your search.
Double dot .. lines are quotes from Tito's posts scattered over the years.
Part 1, Charge:
Tesla patent 568177 fig.1
..it is actually convertion of small kicks into big kicks...
..A FULLY CHARGE CAPS ENERGY CAN PULSE A COIL A LOT OK, INTO A POINT THAT IN THE FIRST PULSE WE CAN CHARGE IT ALREADY
..just in one pulse only ok?
..note: we only need volts to energize a caps
..i want you also to discover the DC way of amplification
This is a small version.
http://overunity.com/3852/tell-the-truth/msg68126/#msg68126
http://overunity.com/3852/tell-the-truth/msg68150/#msg68150
http://overunity.com/3852/tell-the-truth/dlattach/attach/16085/
Tesla patent 568176 fig. 1 & 2
..Lets say we have a fully charged caps, if we make, make/break very fast, the caps will not fully discharge, and we can replenish it and back charge it in just one very fast make/break ok?
..making a ringing effect inside the two caps prohibiting a discharging action from the source, and as it is ringing then a magnification is being done at the other coil.
..Discharge a cap on a very thick wire coiled in a bifillar form is very efficient making a very powerful magnetic field ok.
..P.S. Bigger magwire makes strong magnetic field isn't it?
.. discharge a fully charge capacitor in a very thick wire with tail, this will give you an excess energy and this is the secret!. tail = extra coil.
..technique of using other coil making a kick without using any current from the input and that makes excess or unlimited energy.
http://overunity.com/6763/energy-amplification/msg433628/#msg433628
http://overunity.com/6763/energy-amplification/msg433751/#msg433751
Part 2, Discharge:
Connect to patent 568176,
step 1:
http://overunity.com/6763/energy-amplification/msg435120/#msg435120
..only at peak switching very very little energy is used
..is it not that a bridge rectifier can accept ac that is two different direction electricity combining them into one?, and with the help of a cap, the point of cut is being filled.
..let one arm of the coil be connected already to the cap when charging it so that it becomes more efficient ...
..i used input, and the effect of the input, witch is the output, and redirect it into a normal power amplification method
..and since we know that a diode can permit a current and voltage to pass then why not after the diode lets make a lot of coils but not permitting bemf to go back
..Now, what we want is to eliminate the direct flowing but the whole energy effect is being use by us
..The thing that should be happen is that, as if you are using the source but not actually destroying it but you are using it.
..For every single pulse there should be an accumulation happening.
..like what i already said, battery can solve grounding ok,
..WE ARE ALREADY LIVING IN SEA OF ENERGY JUST HARNESSED IT.
(We are living on a sea of energy: Cadman)
step 2:
..alternately discharge this caps in a transformer
..study the real process or the real thing that is happening when charging many caps of at least 10K uf in high voltage dc and discharging it sequencially in a coil with secondary!
..you are correct all caps are in state of being charge then discharging them one at a time i mean extremely fast ok.
..plus the real output so you get the used energy and the output energy be added then you get excess then make some little charging action to make battery always alive ok.
@forest
..hi everyone here is my simple idea to convert HV into L-Volts
..note : You must know first the highest voltage AND CURRENT that you can get ok.
..many transformer then connect the primaries in series then connect all secondaries in parallel ok thats how simple it is, cause it will act as a single transformer ok
Thanks to all the members who shared their ideas and pieces of their research.
Best Regards
Cadman
Hi guys, been a while since i've posted, thank you sir cadman for collecting valuable posted info.
We can mix things up like tinselkoala's emj replication, 6v input, 4kv output!,  :o  [size=78%]also the sergei transformer with bucking output windings.....so many techniques....need only experimentation....we can do this! Or should i say you can do it! Lol.....[/size]
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%]Regards [/size]
[size=78%]Cc[/size]
Magluvin
Quote from: crazycut06 on February 08, 2015, 07:31:14 PM
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%]Cc[/size]
ditto on that.
Just made a coil setup on 1 1/4 pvc, lil over 10 in long, using radshack 30awg(red).  Will put pic up later.  Didnt count turns. I put 3 plastic pins in the side, 1 in the middle and 2 'equally' spaced towards the outside. On coil wound one way and the other opposite from the center out.  Then im making a mix for a core from iron powder and granules, some the size of sand and fiberglass resin. The core will be pretty large, 1in x 10in.  My reasoning for this direction im heading in is to increase voltage on the coils and lower the operating freq as much as possible.   Might have to get some big rubber gloves like Tito said. ;D   Compared to the other thread, the voltage might be way out of hand. :o    Will do testing at a distance.
4kv from the coils they are using is not a common happening. Typically 1k like TK said he would have possibly expected. Considering input used and all.
Back when I made my Lil TC, I had a 1 loop turn around the top of the secondary and it lit a small 12v light bulb. At the time I was showing pics, it seemed like Tito wanted to change the subject real fast. (No offense Tito ;) , Just thinking I may have been on to something and you didnt want it to go any further. If we are going to get this, we may need to use clues that may not seem like clues also.) So now, Im really wondering how 1 loop(or 2, 3, 4 loops) will work on this coil.  That 1 loop was at the top of the sec, sec not loaded, open ended.  It was brightest at the top of the coil near the open end of the sec.
This all has me a bit excited again. Just kinda lost it for a while. Hopefully it pans out. ;D
Was going to make a toroid like the one I added to Titos circuit in my last post here, but I wanted to try this first. Dunno why. Just wacky I guess. :o :o
Toroid will be next. Well, closed ecore, as I have a few. Easier wind also. ::) ;D
Been workin a lot, so couldnt get to this until the last couple days. I have some time to fiddle for the next week.
Mags
Magluvin
Oh yeah, forgot to put up pic of coil. Nothing special. Opposing coils.  Will be working on this more on the weekend.
Thinking of making a vid when i make the core.  Thinking to use an automotive paint filter, paper cone with fine screen at the bottom point, to allow the resin to drain out and have more density of iron particles in the core. Making the mix thinner with more resin will allow me to pour it in, avoiding air bubbles from shoving a putty mix in.
Then Ill make a couple primary coils, bifi, as Tito has stipulated, to try some things.
Mags
Magluvin
Tried to think up a primary. Just went with it, 2 rolls of RS green mag wire to make a bifi primary. Made the spindle of pvc pipe and pvc hobby plastic. Wound a single layer of the RS 30awg under the green bifi to use as a monitoring coil.
Will set the long tube on standing posts at each end and set a small square base for the primary to be at the right height to the sec tube to be centered. And be able to slide left and right.
Havnt done the core yet.
Mags
Magluvin
Had an oops with the bifi when winding it and the final layers are not great. Unwound on me a bit.  Will redo later. Try it as is.
Mags
