ENERGY AMPLIFICATION
0 Members and 61 Guests are viewing this topic.
Magluvin
Below is a pdf that I found interesting.
It shows how to make a capacitor that produces a magnetic field. Was a Tito quote. ;)
And near the end of the pdf is a circuit that reminds me of Titos first circuit. Also posted below.
Mags
Bob Smith
Nice find, Mags.
Here's a thought. If you're gathering power with an antenna that can bring in enough charge to power an oscillator, you shouldn't have to have the loop-back in the system.
Bob
Edit:   I wonder if the HV module can simply output to a regular primary coil. I suppose the advantage of the Tesla coil lies in part in its tuning and resultant resonant behaviour.  The cw-ccw center-tapped secondary, if properly wound, should allow charge to be drawn it without disturbing the primary's resonance. But all 3 coils (primary and each half of the secondary) need to be balanced for that to happen, I think. It's interesting though, that Teets was talking about the TMT for awhile as the model for what he was doing.  This arrangement of coils would seem to approximate that, in my estimation.
Magluvin
Quote from: Bob Smith on March 12, 2015, 08:42:13 PM
Nice find, Mags.
Bob
Hey Bob
Tito did say recently about a cap that produces a magnetic field. What is interesting is, I made a similar cap like that, not to those specs though. Also I was trying is as a secondary, not as a primary, and not near those voltages shown in the pdf.
Also interesting, using it as a primary, it is still a cap. More like an open ended winding rather than a winding connected from end to end to the circuit. Has me wondering if the cap primary could just be wire bifi coil and the opposite ends of each coil dont have to be connected to anything. The difference would be that the foil cap would have way more surface area and capacitance than a wire wound bifi, let alone all the resistance of the length of wire it would take to get as much capacitance.
This coils setup I made is possibly all wrong in comparison. Also im not looking to blast it with 40kv. So I wonder if anything good can be had at lower voltages for input.
In Titos circuit drawing, where it shows just 2 output leads, so it could still be the same as in the pdf as the 2 outer ends of the sec are connected to the same post on the bridge rectifier. If it is the same transformer that Tito used, he hid it well by making it seem like an ordinary transformer used in reverse of what it was intended for. But then again, it is a bit confusing, as Tito had described it as what would seem like many turns on the primary vs the sec, a 10 to 1 ratio(240v/24v).  So I dont know yet.  But most likely the key is to have the sec as shown in the pdf.
Anyway, got all weekend this week to play. So hopefully something good comes out of all this. ;)
Mags
