ENERGY AMPLIFICATION
0 Members and 64 Guests are viewing this topic.
Magluvin
Oh. lots of switches not needed?  The diode voltage multiplier is charging each cap in parallel with the battery, and the caps are already in series?? But they are not in series with the battery I wouldnt think. So some switching. I dunno.
So just transistor pulse each cap into its own primary in succession loop?
Mags
a.king21
Mags: just build a tesla controller switch.
transistors  cannot handle this kind of disruptive discharge.
There is an old patent to this effect, and it also closely resembles Benitez's battery switching patent.
If you can figure out a way to do it electronically I'm all ears.
Maybe you should look at MAGNETIC AMPLIFiERS.
Magluvin
Quote from: a.king21 on March 24, 2015, 01:34:26 PM
Hey Aking
Well I was thinking that this may be a low voltage circuit. Not many 10kuf caps at 1000v or better out there. Is there?
Mags
a.king21
Quote from: Magluvin on March 24, 2015, 05:16:37 PM
Hey Aking
Mags
No-one has mentioned 1000v. It's a 12 volt battery x 3 = 36 volts max.
If you want another  low voltage device you could build this:
http://www.instructables.com/id/Bedini-Monopole-Mechanical-Oscillator/
Magluvin
Quote from: a.king21 on March 24, 2015, 07:23:51 PM
Im just sayin, transistors can handle 36v or 12v pretty good. So no need for a switch wheel with a driving motor and probably have to regulate the speed(another circuit) for optimum.
Saw som 10,000uf at 200v. Still can transistorize.
Mags
